Results 1 to 6 of 6
Thread: Heater / A/C fan only worked on high
    Jun 2016
    1999 black & 2001 yellow
    I guess I'm a cheap type and really not too much on keeping my beater in stock form.
    Those resistors are just too freakin much !
    I found a $7.00 fix. Seems to be working just great and I can choose the best speed of the fan for comfort. It seems to blow more also, maybe it sends more juice to the motor than a stocker on full speed..
    http://www.ebay.com/itm/111851538617...%3AMEBIDX%3AIT
    Jun 2016
    Oct 2014
    1999, White, Ironman, and 1999 Astral Silver
    You just needed to replace the resister inside the heater core housing. Common problem with all vehicles.
    Jun 2016
    As I stated above. I knew what it needed, I know it would cost.. So how much would it cost to replace all the resistors with new ones ? Why just replace one when they all are all the same age and about the same use.$30.00-$50.00 each. A LOT !!! I put this up as a affordable option that works. As a matter of fact it works better than OEM as I have infinite control of the speed of the fan for any speed and it seems to go to a higher speed also.
    Jan 2015
    1999 Ebony VX, 0209
    Nice find. My only concern would be, as you stated, you can now push the motor faster. Remember that the fan motor is old as well. Running it past it’s design limits can be sketchy when something is new. I am not saying it will damage anything, but keep in mind the potential is there. Still, good find.
    Jun 2016
    Ever since you have been reconnoitering the engineers design.. I will just add that it might be designed to run twice as fast as my fastest speed to keep the dust and dirt away from moving parts.. I do believe that it was designed to run at 14.2 volts just like everything else. I didn't go over that..
  7. The Following User Says Thank You to Nikad92397 For This Useful Post:
    CatFish (02/23/2018)
  1. ABS Unit - I can't believe this worked!
    By bartmanS4 in forum VX Troubleshooting...
    Last Post: 11/23/2012, 10:20 AM
  2. Heater
    By Hol_VX in forum VX Troubleshooting...
    Last Post: 09/05/2010, 03:27 PM
  3. High idle/ high power steering pressure?
    By Rene M in forum VX Troubleshooting...
    Last Post: 09/22/2007, 03:21 PM
  4. Replies: 7
    Last Post: 08/03/2007, 05:33 AM
  5. WOW... Warranty worked for me!
    By driver3 in forum VX Talk...
    Last Post: 03/30/2006, 02:53 PM
