Originally Posted by
Y33TREKker
maxprime
Is there another relay between the rt fender power block and the control module that could be bad and powering it? If I pull the relay on the power block. It shuts havc controls off.
I checked the fuse box behind the battery and tested the relay connectors and found 2 are constant power on relay eb 25 and the center one is powered on eb 27 without the key on. I checked them against my 99 vehicross and only one is powered on eb-25 and none are powered on eb-27 with the key off. I made a diagram to show which are hot with the key off by marking them in "red".
Did you check with a voltmeter that the EB-27 (Starter Cut) relay showed proper continuities when you had it removed?
It should show continuity between pins 2 & 4 (the internal coil), and continuity between pins 1 & 5 when pins 2 & 4 (Normally Open switch) are energized with battery 12 volts. If continuity between pins 1 & 5 is present at all times, the relay is stuck or shorted (which would be keeping the Heater A/C relay energized at all times and applying power to your Auto A/C controls).
I did not. But, I will tomorrow. I hope that is it. thanks again.
81 AMC SX/4 "Go Mango Orange", 99 Vx "Astral silver",01 Vx "Proton Yellow", 02 H1 "Competition Yellow" and "lil pigglet" 05 Zuma "Team Yamaha Blue/White"
