OK, lesson learned and sort through the thousand posts first before you do ANYTHING. Was loosing power steering fluid. Narrowed it done to the Power Steering Pump Pressure Hose. It turns out the Pressure Hose (Fexlible Hose) bolt was seized into the Power Steering Pump Connector. So Bolt, Connector came out as one unit and spring and Value shot out. So I don't know which way the valve goes back in? Can some one please help? Also not sure how to post image, hope this works. [IMG]/Users/litlbear/Desktop/photo 1.jpg[/IMG]
