 Originally Posted by
creeg
Would it be best to get a 5-wire hookup for now, and then I can plug in a 4-wire converter if needed?
I had problems when I tried using one of these on my VX. Now, could of been the converter was bad, maybe the LED lights I had installed was causing issues, maybe the electronic flasher,
maybe the installer... Me
In the end, I did it the old fashion way. I used one of the 4 wire trailer connectors you can by for 10 bucks or so. I used the trailer tongue to tow hitch as ground, four wires, one for brakes, left turn, right turn, lights, works fine and saved a few bucks. Now mind you, that trailer is tied to your vehicle. You won't be able to tow another trailer or tow your trailer with another vehicle unless you make an adapter.
anyway, another option
				Greetings, Earthling. We come in peace... Never  mind "Paris to Dakar", the VehiCROSS looks ready for the Martian desert.
