Results 1 to 7 of 7
Thread: bank 1 and bank 2 sensor 1 both sending errors. why?
    Nov 2010
    2001, White, Ironman
    A couple months ago I installed a rebuild engine. while it was out i installed four new o2 sensors because they were easy to get to. This was under 1000 miles ago. Im getting error codes for both sides sensor 1.
    does anyone have any idea why? ever seen this before?
    '01 Ebony #0939
    You might try just disconnecting your battery for awhile to clear any stored CEL codes, then connecting again to see what happens.
    If the engine was rebuilt, the O2 sensor values that were being stored before the piston rings got seated may not have been similar enough to the readings the sensors are seeing now? Resetting the computer now that those readings should at this point remain more consistent may do the trick.
    Easy enough to try anyway.
    Nov 2010
    Hmm no luck! It was looking good for about 20 miles then the codes popped up again. Same exact ones.
    Nov 2007
    1997 SILVER
    What are the exact codes??
    IIRC there are a few different codes for O2 sensors, and that might give us a clue.
    PK
    Nov 2010
    P0133
    Oxygen Sensor Circuit Slow Response (Bank1, Sensor1)
    P0153
    Oxygen Sensor Circuit Slow Response (Bank2, Sensor1)
    Oct 2015
    2000, yellow, vx, 231
    •Intake air leaks
    •Gas leaks in the exhaust, located near the oxygen sensor
    •Broken, bare or shorted wires leading to the oxygen sensor
    •A faulty oxygen sensor
    1999,silver,vehicross,1891
    I get code 141, faulty sensor heating circuit, I am going to have sensors cut out, new mounts welded in and new sensors mounted......... my old ones are totally fused in place
  1. Buying a VX and sending to Mongolia. HELP!
    By Hybrid1098 in forum VX Talk...
    Last Post: 10/16/2011, 11:49 AM
  2. Fuel Sending Unit?
    By xdfarrx in forum VX Troubleshooting...
    Last Post: 11/14/2006, 11:09 AM
  3. Bank 2 Sensor 2 replacement tip
    By Maugan_VX in forum VX Troubleshooting...
    Last Post: 04/13/2006, 03:35 PM
  4. Mods funded by your local BANK!
    By VCAMILO in forum VX Talk...
    Last Post: 04/07/2004, 07:55 AM
  5. Do not bank with NetBank
    By tiggergreen in forum VX Talk...
    Last Post: 10/12/2003, 04:39 PM
Tags for this Thread
