Results 1 to 9 of 9
Thread: Alpine Supercharger hose issue
    Discovered that a hose, directly behind the supercharger, identified by two hose clamps on top and bottom has become so porous and it must be replaced. I'm not sure how to go about it and would appreciate any information from anyone who's had to replace that hose.
    Scott
    The picture shows a sideways view
    Attached Images Attached Images
    Scott
    I have never had to bother with this line. I would imagine it is just regular plumbing. Hopefully you can just tear it down and just cut the same size new hose down to fit. Sadly, "tear down" seems the likely scenario here. Plan for at least 1/2 a day. In any case, make the best of it and replace any other lines, gaskets, and maybe even the S/C oil while you are at it. Knock as many birds down with that stone as possible. Good luck.
  3. The Following User Says Thank You to WormGod For This Useful Post:
    ScottinMA (04/15/2016)
  4. #3
    Stand up about two birds with one stone...classic if you like a dry British type of humor.
    https://www.youtube.com/watch?v=71gilEP4aJY
  5. #4
    Jun 2015
    dont, have, one yet 1111
    ...not meaning to threadjack...but is there any supercharger kits still available anywhere?
  6. #5
    Ahhhhr...Well JesseB there are plenty of threads about your question so lets not highjack this. The hose in question is very interesting. When removed there is a "restrictor" inside the hose that narrows the diameter from the SC to the intake. And since Alpine no longer exists there is no replacement.
  7. #6
    Quote Originally Posted by ScottinMA View Post
    I am assuming you can still just pull off the old hose and slide a fresh cut one in place though, right?
  8. #7
    The hose
    is in rough shape so it really needs to be replaced
  9. #8
    Was finally able to construct a hose within a hose to replace the deteriorated existing set up. So the moral of the story is, if you have an Alpine supercharger, you might want to check the condition of yours. I also came across the following email address: sales@performancesi.com which I used a while back to replace the 5 pound pulley. So I gave it a shot but never got a response. That company apparently purchased Alpine and was supplying parts for a while. If anyone reads this and has information as to where we can now obtain alpine supercharger parts that would be a big help.
  10. #9
    99 Silver 515
    Tried the email as well and it was bounced back...
  1. Alpine supercharger belt number?
    By JULIAN911 in forum General Tips...
    Last Post: 08/24/2014, 12:31 PM
  2. Supercharger Alpine Mounting Instructions
    By piluf in forum VX Modifications...
    Last Post: 02/15/2012, 07:00 AM
  3. Alpine S/C install PDF
    Last Post: 04/06/2010, 01:12 AM
  4. Alpine Supercharger Manual Available
    By BeeVenom in forum VX Modifications...
    Last Post: 07/19/2009, 10:34 AM
  5. Alpine Supercharger's Customer Service Improved!
    By Tone in forum VX Modifications...
    Last Post: 06/08/2007, 12:48 PM
