Results 31 to 38 of 38
Thread: Cladding Restoration
Threaded View
    Mar 2012
    2001 Ebony #0254
    Thanked: 16
    *I do NOT recommend Forever Black*
    I applied the product to the VX and waited a week before washing it, I went to the car wash and washed it as I normally do (run of the mill do it yourself high pressure car wash) after I rinsed it I noticed some area looked discolored so I drove home and waited to see how it looked after drying it. Well it looked like crap, some of the product washed off and it was then splotchy grey and black. They claim it dies the plastic but it did not on the VX. I cleaned and prep'd it better than they instructed so I do not believe that was why it did not color the cladding. I plan to remove it all at some point and just live with it the way it is, I am not impressed with the results.
    I have been testing a product and I know some others have also been trying some restoration products too, so I am starting a new thread about this because most of the threads I found are so old the products used in them are no longer available so I am going to post what I found here and hope others will post their recent finds here or links to other recent threads I may have missed.
    I am only testing the products that claim to dye the plastics and rubbers because I have tried at least 10 different reconditioning type products and none of them lasted longer than a few months on my VX.
    My cladding was very chalky when I got it and all the products that did not add color or have a dye in them lasted less than a few months, I think some of the products made mine look worse the cladding would get streaks and spots on it after a rain or snow and stay that way until I reapplied some more product.
    I am trying Forever Black and have tested it on a spare piece of cladding. I did use a degreaser and then after that I cleaned it the cleaner they provided to be sure all the layers of grease and silicone products I tried on it were removed before using the dye. Here is the youtube product video. It says permanent and then says should last years which is longer than to so called permanent hair die I use, I think the permanent refers to not being able to wash it off or remove it once it is applied. After I dyed it and I did spray cleaners and degreasers on my test cladding, scrubbed it and rinsed it then I rubbed it dry with a towel and none of the color came off or changed.
    https://www.youtube.com/watch?v=wNfQUq8soBg
    My PhotoBucket with more pictures of the cladding and the product packaging. http://s920.photobucket.com/user/Red...?sort=3&page=1
    Before applying any products.
    First coat and section, you can see some white spots and scrapes next to the first section, the dye does cover them completely in the next picture.
    Second coat over the first one, I cannot see the line from the first section I did.
    I left it oustide for a few days in the snow and let the snow melt on it to see if it streaked like the other products did.
    I did one more section and put it on as tin and light as I could to show a very thin coat.
    This picture shows from left to right, no product at all, a very thin light coat in the middle and a good coating on the right.
    I am going to do the VX based on my findings, I think it looks good and as bad as the VX looks I have nothing to lose. I will post before and after pictures of the VX when I do it and try and remember to post a picture every 6 months or so to see how it compares to the initial application.
    I think this stuff is similar to the showroom new used in this thread.
    http://www.vehicross.info/showthread...light=cladding
    I could not find showroom new anywhere so I moved on to the forever black.
  1. Cladding restoration
    By Cstoops72 in forum VX Modifications...
    Last Post: 08/31/2014, 02:55 AM
  2. 3M Headlight Restoration Kit
    Last Post: 11/09/2012, 10:58 PM
  3. Cladding Restoration...so Easy & Dope!
    By mike nomy in forum General Tips...
    Last Post: 04/10/2012, 09:02 AM
  4. VX Restoration Begins!
    Last Post: 02/02/2012, 09:39 AM
  5. Headlight Restoration
    By crager34 in forum General Tips...
    Last Post: 02/04/2008, 11:48 AM
Tags for this Thread
