Every time it rains, I end up with water on the floor of the front passenger side compartment. It took me a while but I finally figured out where it is coming from. My right roof rail leaks. Water runs across the headliner (which apparently is waterproof), then down the right front pillar, then eventually finds is way onto the floor.![]()
Has anyone removed one of the rails before? I figure it must be bolted on from underneath the headliner. I wonder what they used at the factory to seal it?
