Results 1 to 6 of 6
Thread: Found the squeaky cricket that is my Hood, but how do I suppress the Noise!!?!!
    Jan 2011
    99,Silver, Vehicross 0451
    For months I've tolerated this ever growing squeak coming from the Vehicross. After replacing the balljoints and tie rod ends, decided that I had to address the issue. It seem when I open the hood, no more squeak!
    But when I close the hood, the squeak returns. Does anyone know "where" or how can I muffel the noise? I spray WD40 on the (2) hinges....that had virtually no effect! Any suggestions would be Most welcomed.
    Thanks for reading.
    Drive Safe!
    Jul 2014
    2001 Pearl White Vehicross 1455
    It's probably the latch, not the hinges. Mine does that when I'm off roading. Grease the latch and the pivot points.
    Current caretaker of The elusive 2001 "Pearl White" VX - The last one.
    1988 BMW 325ic
    '01 Ironman #1109
    Quote Originally Posted by jtirado View Post
    Thanks for reading.
    Drive Safe!
    There are a couple of rubber bump stops underneath the hood near the front. You can adjust the height by turning them. Extending the stops will keep the hood from rattling around too much and making squeaky noises. I believe counterclockwise will extend these stops. Just adjust both in quarter turns and drive around after each adjustment to see if the squeaks disappear. Hope this helps.
    www.aftershockproducts.com
    Agree with Rudy...if they're like mine then they are TOAST but you can still get them new from isuzuparts.com at a good price.
  5. The Following User Says Thank You to Mile High VX For This Useful Post:
    CatFish (02/14/2016)
  6. #5
    Jan 2011
    You guys are the BEST, that's why I love coming to the site...keeps my Vehicross rolling!!!
  7. #6
    Jan 2011
    The rubber bumps did the trick...I never thought silence would be so golden...no offense to Crickets!!
  1. You won't believe what I found in my VX
    By Marlin in forum VX Talk...
    Last Post: 08/17/2012, 10:26 AM
  2. Found these
    Last Post: 12/31/2010, 07:05 AM
  3. hey I found this on the web
    By circmand in forum VX Talk...
    Last Post: 07/18/2010, 06:36 AM
  4. Squeaky front end.
    By lostemple in forum VX Troubleshooting...
    Last Post: 10/14/2006, 06:20 AM
  5. Check Engine Light ..Squeaky bonnet
    By moon buggy in forum General Tips...
    Last Post: 02/28/2006, 04:06 AM
