Results 1 to 3 of 3
Thread: Replacing the fluid in transfer case?
    Nov 2014
    2001, white, ironman
    I haven't been able to get a clear answer on what fluid to use for the Vehicross's transfer case.
    I read some on gear oil, transmission oil and others. (I'd like to get the most premium)
    If I could use transmission fluid, would it hurt to add in Lucas Oil as well?
    From the shop manual:
    TOD system DEXRON) -III Automatic transmission fluid.
    Not sure about using Lucas in the TOD...I just use a good quality synthetic transmission fluid.
    Mar 2015
    I wouldn't put additives in a fluid. The more heterogenous the mixture, the more prone it is to sheering/breakdown. I think I've been using Valvoline full synthetic Dexron VI for nearly all of my trans changes for several years.
    http://www.valvoline.com/our-product.../dexron-vi-atf
    I don't know about the finer points of how these full synthetics are made--and which brands may be superior to others...but I swear by this stuff. every 15k. Full flush/change every time. Comes out as pink as it goes in.
    I do the same thing with Shell Rotella-T6 full synthetic & 3000 mile oil changes. Religious changes. No problems. I've been checking my fluid every fill-up, and I don't appear to be burning any at all. *knock on wood*.
  1. Transfer case #'s
    By simonsayz1 in forum VX Talk...
    Last Post: 01/29/2015, 01:01 PM
  2. Where is Fluid Fill on Transfer Case?
    By Ikkesh in forum VX Troubleshooting...
    Last Post: 01/28/2009, 08:01 PM
  3. 2WD transfer case?
    By So-CalVX in forum VX Talk...
    Last Post: 03/03/2008, 09:40 PM
  4. Transmission Fluid Filter Transfer Case Fluid Change
    By driver3 in forum VX Troubleshooting...
    Last Post: 09/16/2005, 03:23 PM
  5. Transfer Case
    By yal^ in forum VX Troubleshooting...
    Last Post: 04/16/2005, 10:12 PM
