Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Thread: help, Revs going wild up and down
    Thanked: 7
    This is a pic of the harness that I spoke of earlier.
    My mechanics explained that if the RPM's ran high or were fluctuating, to giggle this harness and see if any change occurs.
    Located in this bunch of wires is one that controls idleing. My Isuzu mechanics have found in a number of Isuzu's that that wire can fray and even ground out.
    Granted there are other reasons for an idleing problem that are more common, but here is another possibility.
    ;Dr;
    Anita
    2000 Ebony #263
    AnitaProtich.com
    2001, Black/red VX
    This is similar in a way to the problem my VX had and took the dealer 2+ weeks to figure out.
    In the mornings when cold the car would NOT hold idle. Turn her over and drops from 800 to 0 and dies. After 4-5 times starting the car would sit there and hold idle at would I kind of figure is around 300 RPM. (not enough to do anything). Shut her off and back on 2-3 more times never having moved and WHAM jumps to 2000 rpm and sits there. Drive it for a block and then it is fine. The problem then stops for 2-3 weeks. Then this last Friday in stop and go traffic it did it on the freeway (that really sucked). Took it to the dealer and they ended up replacing the idle control sensor, some intake gasket, and about 6 other things. (which I think were just replaced to take on to the labor they get paid as it was under warranty still).
  1. Man vs Wild
    By djvx in forum VX Talk...
    Last Post: 09/03/2009, 12:30 PM
  2. high revs
    Last Post: 08/05/2009, 04:34 PM
  3. Car revs on it's own
    By 99VX4x4 in forum VX Talk...
    Last Post: 04/25/2005, 02:12 PM
  4. Revs on its own
    Last Post: 04/06/2005, 09:30 AM
  5. Alarm Gone Wild
    Last Post: 07/26/2004, 02:02 PM
