Results 1 to 7 of 7
Thread: Axiom transmission in VX
    Oct 2012
    2001, Proton, 0586
    We all know that 02/03 Axiom engine works great in VX ( http://www.vehicross.info/showthread...E1-%28late%29? )
    But what about Axiom transmission? Is it compatible?
    Mar 2015
    Probably impossible to determine without a direct test-fit. A couple things I'd look at though. 1st, check the actual transmission part numbers. I'm unfamiliar with the Axiom trans, but if it's also a 4WD TOD, 4-speed trans, then it's likely got the same internals as the VX trans. As an example, my Mitsubishi GTO runs the same ATX trans internals as the AWD DSM's; the difference is the bell-housings. Second, I'd verify that the location of the trans is in the same spot in the Axiom as in the VX, and that the bay layout is fairly similar. Getting overall external measurements should help.
    The good news is that if Axiom engines are fairly plug/play, then the Axiom trans should also bolt up fine. It's just the clearancing that might present a problem.
    Oct 2012
    2001, Proton, 0586
    Right, that is why I was hoping to find someone who might have done this swap.
    I am pretty confident that mechanically they will fit, my biggest concern is with the electrical compatibility.
    And you must be talking about automatic Mitsu transmissions, because manual transmissions are quite different
    Mar 2015
    Yeah, the Getrag's are POS's--and super expensive to repair. That's why you see so may people drag racing with the w4a33/f4a33.
    Oct 2012
    2001, Proton, 0586
    Looks like junk yard interchangeability guide shows that 98/99 Trooper transmissions are compatible with 99-00 VX. Which leads me to the follow up questions:
    Was '01 transmission actually different from '99-'00 or is this just a mistake?
    What changed in '00+ Trooper transmission? Is this something significant or just a matter of switching some sensors?
    You might do better to hop on the Planet Isuzoo forum and ask Jerry Lemond.
    Quote Originally Posted by Leon R View Post
    VX 00 & 01 are different than the 99. Some of the solenoids changed. If you pick up a 99 tranny for an 00+ VX you'll also need the tranny computer.
  1. Axiom engine
    By Nikad92397 in forum VX Modifications...
    Last Post: 09/17/2016, 06:51 PM
  2. Is the Axiom center cap the same as the VX 18s?
    By kodiak in forum VX Talk...
    Last Post: 11/24/2008, 08:57 AM
  3. Axiom...
    By So-CalVX in forum VX Talk...
    Last Post: 08/30/2008, 11:04 AM
  4. Shocks For Axiom
    By spawn1980 in forum VX Troubleshooting...
    Last Post: 02/10/2006, 03:32 AM
  5. second hand VX and Axiom
    Last Post: 11/17/2002, 09:26 PM
