ok FYI if your having the same problems with your tranny and thihk its your selonids it may not be, i had mine replaces and had the same problem, took my car to a transmission specialist and told me i had a code for the MAP senosr and that may be causing this issue. I replaced the sensor and whala no more problems. very cheap simple fix.
