Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
Thread: front AXLES availability choices
    Oct 2005
    2001 Proton Vehicross
    Ok those helped fount the snap rings got cv shafts off but now trying to see how to remove the axle from inside. He does t talk mych bout that just dropping the diff
    Dan/2001 Proton/MD
    Nov 2012
    I think once you remove the four bolts for the bracket the axles will pull out.
    There's no 'I' in denial.
    Mar 2015
    I gave up and took it to Coyote Tire in Glendale. Originally wanted to just have the CV boots replaced, then I learned that the labor involved (I was quoted ~9 hours) was roughly the same as for replacing the axles, so I opted to just replace the axles altogether. IIRC, they got a new right axle, but had to send the left out for reman at a local shop. It's been a few months though.
    Oct 2005
    An thanks bart i got it all out an apart. It was the trickey multiple snag rings an pressed bearings that i had to figure out
    YOWSA!!!!!
    Quote Originally Posted by ipd View Post
    Thats an insane amount of hours..if you are talking 1/2 shafts...they get done over a cocktail in Moab every year
    Also..the half shafts are the same both sides...so they should of been able to get 2...??
    Gimme a buzz next time Dave , if you need any help with that kind of stuff.
    Jo
    Oct 2005
    9hrs dam lol its an hour or 2 job tops to pull the whole shaft out an pop a new one in. What crooks
  1. CV boots (or replace both front left and right axles)
    By VXD959 in forum VX Troubleshooting...
    Last Post: 03/29/2013, 05:40 AM
  2. Front Axles Replace or Boots?
    By Breezy in forum VX Troubleshooting...
    Last Post: 09/17/2011, 08:03 AM
  3. front axles
    By brainwashed in forum VX Talk...
    Last Post: 03/20/2011, 09:42 PM
  4. Need Front Axles
    By Bimati in forum VX Troubleshooting...
    Last Post: 04/15/2007, 10:23 PM
  5. GAUGE choices?
    By jayfotos in forum VX Modifications...
    Last Post: 10/06/2004, 09:36 PM
