Results 1 to 6 of 6
Thread: Hubs Too Hot?
    Apr 2012
    1999,silver,VehiCROSS,0273
    Hubs Too Hot?
    I have 1999 VX Astral and was wondering if the front hubs should be really hot to the touch after driving only 20-25 min. on the highway? No recent work or changes on front end either.
    '01 Ebony #0939
    Quote Originally Posted by nairbnuapak View Post
    Is it both hubs? I'd first suspect a brake caliper not releasing, but it would be very coincidental that both would start doing it at the same time. Do you have to use the brakes a lot during the 20-25 mile stretch of road you're referring to? When was the last time you bled your brake lines and installed new fluid?
    Another possibility would be that your front wheel bearings need to be repacked, but brakes would be the first system I'd check into.
    Mar 2015
    Stuck caliper. Could mean that you need to rebuild/repack your calipers. There will always be a tad bit of friction, but nothing that should cause your wheels to get very, very hot like that--especially w/o braking.
    Apr 2012
    Got wheels off the ground and made sure brakes weren't dragging didn't seem to be a stuck caliper. It is both sides and I've never packed the bearings in the 3 years I've had it . Is it fairly easy to do'em?
    2000, Ebony, VX, 0370
    Thanked: 12
    Repacking the front wheel bearings isn't too hard, but it does take some time. I've done mine twice now and I have followed Kenny's write up both times:
    http://www.vehicross.info/showthread...bearing+repack
    Couple of special tools needed but nothing too far out there.
    Apr 2012
    Guess I'll try that next. Thanks.
  1. Hot hubs
    By nairbnuapak in forum VX Troubleshooting...
    Last Post: 10/28/2015, 08:27 PM
  2. Locker / TOD / Hubs...????
    Last Post: 04/24/2012, 04:33 PM
  3. How hot do your hubs get?
    By CrnCnn in forum VX Troubleshooting...
    Last Post: 01/08/2010, 04:34 PM
  4. Got My Hubs On
    Last Post: 07/28/2009, 11:36 AM
  5. VX Lock Out Hubs?
    By crossman in forum VX Modifications...
    Last Post: 12/15/2005, 06:31 PM
