Results 1 to 3 of 3
Thread: Need stereo wiring diagram
    May 2013
    2001 proton #1061
    Hooked up a.new head unit in wifes vehicross..but when its all hooked up..its only playing from.the tweeters,and not the door speakers, was hoping someone has a wiring diagram.
    Mar 2015
    Might need a little more info. Are you running components or were you referring to the rear speakers? Did you do any mods to the speakers at all? Were you getting sound out of all of them prior to swapping head units? Last but not least, if you "jiggle" the wires on the back of the HU, does this affect anything? (bad connection or badly wired plug-ins on the HU).
    One thing I've done before is to take speakers & test them on an older, wired, house radio. If I can get good sound out of them there, then it's either in the wires or the HU itself. Don't rule out HU problems though. It does happen occaionally. I had one installed in 2013 that never reliably delivered a radio signal; worked fine with my MP3 player though.
    '01 Ebony #0939
    Could even be the Fader settings on the HU itself dialed all the way to the "Front".
    Was this an aftermarket HU wired to the stock speakers/stereo harness using an aftermarket harness adapter?
  1. Wiring diagram for folding mirror switch
    By Mile High VX in forum JDM Parts & Accessories
    Last Post: 10/06/2016, 08:26 PM
  2. Antenna wiring diagram
    By RabidPony in forum VX Troubleshooting...
    Last Post: 08/27/2013, 10:47 AM
  3. Wiring Diagram for Rodeo needed
    By Raque Thomas in forum VX Troubleshooting...
    Last Post: 11/04/2007, 06:00 PM
  4. wiring loom diagram to download???
    By mad1230_10 in forum VX Troubleshooting...
    Last Post: 09/16/2005, 02:43 PM
  5. Wiring Diagram
    By STEREOSPECIALIST in forum VX Troubleshooting...
    Last Post: 01/07/2005, 09:12 AM
