Results 1 to 15 of 24
Thread: Update on my VX Project
    Nov 2010
    2001, White, Ironman
    Over a year ago i purchased my VX from a guy in Cleveland. I believe he got it from member mbeach (http://www.vehicross.info/member.php/1374-mbeach)
    Had a massive knock
    https://www.youtube.com/watch?v=hTAyxJjyc4s
    took the engine out and tore it apart. It was completely missing the rod bearing on piston #1
    AND a head bolt broke off in the block.
    Took it to a machine shop. They said it would need to be bored out at least 20 over. And they might have to drill out that bolt. Valves were bent on cylinder 1. Piston showed marks from being knocked around. It was a mess.
    So i decided to find a new engine instead of rebuilding this one. Thought about doing an engine swap with an Aurora v8 but i just dont want to have it in the garage for ANOTHER year. Id like to drive this thing finally!
    While it is in the shop i might do some other modifications/maintenance. I already threw a 3in body lift on it - and i believe it already had lift springs and a torsion crank. Im going to get under it with a lot of rust converter and paint.
    Any suggestions on what else i should do?
    fingers crossed there was nothing bad with the transmission or transfer case...
    Oct 2005
    2001 Proton Vehicross
    Do ya still need an engine ?
    Dan/2001 Proton/MD
    Nov 2010
    not any more - looked for a long time. You have one for sale?
    Oct 2005
    Yes
    Nov 2010
    Here are some pictures from this weekend.
    Painted the valve covers and the intake to make it look a little nicer.
    Put 4 new O2 sensors in it while the engine was out so i could actually get to them.
    http://i.imgur.com/HH3zUb2.jpg
    http://i.imgur.com/mUFitDi.jpg
    http://i.imgur.com/evxglF8.jpg
    http://i.imgur.com/AqKYb90.jpg
    http://i.imgur.com/jo3xlym.jpg
    http://i.imgur.com/hfTJULO.jpg
    http://i.imgur.com/O2EOAMz.jpg
    Still to do:
    Finish bolting up the transmission
    Attach the power steering pump
    Accessory belt
    Radiator
    Probably some other stuff that im forgetting
    Mar 2004
    2001 VX Black int/ grey. 84K miles-
    That fresh motor looks good
    keep the pics coming!!
    Quote Originally Posted by rtormet View Post
    Still to do:
    Accessory belt
    Radiator
    Nov 2010
    Ok - im an idiot and forgot to put in a couple of the sensors (cam and knock) before putting the intake stuff on the top of the engine. Well now the engine is in the car and everything was bolted up - blocking my way to those sensors. Time to dismantle.
    feeling like a big idiot right now
    May 2015
    98 ,Steel Blue Mica, JDM,1478
    Doh !
    Any Kiwis here?
    Nov 2010
    Got everything hooked up, plugged in, and ready to start. Put in all the fluids. Put in a battery. Hooked up my electric fan. Hooked up the transmission to the shifter. All looks good!
    http://imgur.com/a/ySdf3
    Turn the key - NOTHING.
    We hear the starter relay in the engine bay click on. All fuses look good. Brand new starter. But nothing happens. Starter doesn't engage. Engine doesn't turn over. Nothing.
    All dash lights came on the first time. The second time the only lights that showed up were ABS, and airbag light.
    When I turn the key to off I hear five beeps coming from the center of the inside of the car. I think it's coming from the hump below the cd changer. Ecu in there? I'm not sure.
    Any help would be appreciated.
    I'm thinking a ground problem somewhere but from what I can tell I have all my grounds plugged in.
    We checked the battery and made sure it was fully charged.
    Everything worked before taking the old engine out.
    Thanks
    Oct 2005
    Believe the Ecu is under pass seat
    Nov 2010
    I was using a new starter (of which i didnt confirm functionality) so i thought maybe it was a bad solenoid or starter. Replaced it with the stock starter that i know started the engine when it was bad. Same exact issue.
    is there a ground strap i might be missing - from the engine block to the frame or battery or something like that?
    Oct 2005
    No straps just the ground from battery
    Nov 2010
    Quote Originally Posted by Lizardmen3477 View Post
    Damn! I was hoping it was something simple I was missing
    Nov 2010
    SHES RUNNING!!
    yay - crazy excited! After having the car for a year and a half its finally running again.
    Broke in the engine for about an hour. Will continue tomorrow.
    No warning lights except for TOD - ill have to investigate!
    The problem was a bad ground running to the engine block. Put on a nice beefy ground wire and it started right up.
    putting the hood on tomorrow - all 4 bolts broke off in the hood itself so im going to have to drill some holes.
    Oct 2005
    Was it the ground from the battery to the block i mentioned?
  1. New Project
    By ohiovx in forum VX Talk...
    Last Post: 11/14/2014, 12:25 PM
  2. New project ride!
    By WormGod in forum Chit-Chat ...
    Last Post: 05/28/2014, 07:04 AM
  3. project Re-Zu
    By VxSport in forum Chit-Chat ...
    Last Post: 07/21/2013, 07:09 AM
  4. New Trailer project
    By RamAirZ in forum Chit-Chat ...
    Last Post: 08/29/2011, 08:49 PM
  5. My project car
    By jdm monkey in forum VX Talk...
    Last Post: 02/22/2009, 09:36 PM
