I have a hot shot intake and cone filter that I bought used and refurbished a while back. The maf sensor is positioned in-line after the filter. I believe the maf needs to be after the filter to get a cleaner reading as it would be prone to contamination if positioned before the filter. Sensor is highly sensitive to dirt which will affect your engines performance and/or throw codes.
