Decided to add an oil catch can to see if that helps with consumption or improves performance.
I modified a power steering pump reservoir bracket from a 2000 Trooper. It's the same as the one for the VX, just easier to source. I cut it down to just the main leg and the clamp area. It was really close to the power steering hoses so I took a small vacuum line, split it, and covered the edge of the bracket for some extra padding and remove any rough edges. I attached it with the same bolt as the power steering pump bracket on the VX, mounting it on top of the existing bracket. A few cut, hammer it out flat instead of that big bend that it has, some paint and done.
The circle clamp holder fit nicely on the catch can that I ordered, but I still cut a can koosie (that foam holder for your soda) and padded the grip. You can't use the really thick ones, just the kind that fold flat. I bought one at Wal-Mart for a quarter.
Turned out really nice in my opinion. I used the OEM clamps from the PCV set up so it has that OEM look.
I also cut out the small square on the edge of the engine cover to allow the line from the PCV, that I took the valve out of, to reach the catch can without any harsh bends.
