Results 1 to 4 of 4
Thread: Steering Box Replaced
    Nov 2012
    Wrench Steering Box Replaced
    Well, after wheeling in Moab with no power steering to the left (the right worked ok) I finally replaced the steering gear box. I still have a parts Trooper so I just pulled the part from it. That is officially a PITA job in case you were wondering
    I have a standard pitman arm puller but was unable to get the joint to separate at the track rod. I went to Advanced Auto Parts and rent/borrowed their assorted puller kit and used the puller marked SML and that one worked great!
    Lower left
    Unbolting the gear linkage, two fluid lines, and the box itself didn't prove too difficult. Getting enough room to drop the gear box out was more challenging. I ended up removing the radiator shroud, removing the airbox, disconnecting the transmission connectors etc to pull them out of the way, and unbolting the two tabs that hold the steering fluid cooler line so I could get it out of the way enough to maneuver the gear box out through the bottom. Once I had the method established installing the replacement was not too difficult.
    Got everything back together though and the steering feels great! Now I need to track down the rattling noise in the front end when going over bumps. Grrrr
    There's no 'I' in denial.
    Oct 2014
    2001 Ebony VX 1092
    Rattling noise could = loose exhaust manifold heat shields?? worth checking
    Jun 2008
    2001,black, vehicross 1353
    Good to hear it worked out.
    Milwaukee WI
    Jun 2014
    2000, Ebony, 0570
    Noise in front end going over bumps... Good luck
  1. rear brakes just replaced, but car kept going!
    By dynofan in forum VX Troubleshooting...
    Last Post: 06/07/2012, 04:13 PM
  2. Replaced Steering Wheel
    By darkl4805 in forum VX Modifications...
    Last Post: 06/16/2011, 06:17 AM
  3. shift shaft seal replaced
    By VX KAT in forum VX Troubleshooting...
    Last Post: 01/29/2009, 06:21 PM
  4. Serpentine belt replaced at 39k miles
    By Bill Brown in forum VX Troubleshooting...
    Last Post: 11/28/2003, 12:29 PM
  5. Anyone else have AC Fan replaced 2 x
    By mdf in forum VX Talk...
    Last Post: 11/26/2003, 06:18 PM
