Results 1 to 11 of 11
Thread: i am new and really need some help withe check engine light
    '01 Ironman #1109
    Have you tried resetting the comp by unplugging battery for 15 minutes or so to clear the code? And see if it pops up again when you replug?
    www.aftershockproducts.com
    A code P0171 may mean that one or more of the following has happened:
    •The MAF (Mass Air Flow) Sensor is dirty or faulty
    Note: The use of "oiled" air filters may cause the MAF to become dirty if the filter is over-oiled. There is also an issue with some vehicles where the MAF sensors leak the silicone potting material used to protect the circuitry.
    •There could be a vacuum leak downstream of the MAF sensor
    •Possible cracked vacuum or PCV line/connection
    •Faulty or stuck open PCV valve
    •Failed or faulty oxygen sensor (bank 1, sensor 1)
    •Sticking/plugged or failed fuel injector
    •Low fuel pressure (possible plugged/dirty fuel filter!)
    •Exhaust leak between engine and first oxygen sensor
    A lot of times, cleaning the MAF sensor and finding/fixing vacuum leaks fix the problem. If you're on a tight budget, start there, but that may not be the fix for certain. So, possible solutions include:
    •Clean the MAF sensor. Consult your service manual for it's location if you need help. I find it's best to take it off and spray it with electronics cleaner or brake cleaner. Make sure you are careful not to damage the MAF sensor, and make sure it's dry before reinstalling
    •Inspect all vacuum and PCV hoses, replace/repair as required
    •Inspect all hoses and connections in the air intake system
    •Inspect and/or test the intake manifold gaskets for leakage
    •Check for a dirty fuel filter and proper fuel pressure
    •Ideally you'll want to monitor short and long term fuel trims using an advanced scan tool
    •If you have access, you may want to run a smoke test
    This is a handy document to keep available. It contains hyperlinks to what I posted above.
  1. first check engine light
    Last Post: 04/26/2010, 07:36 AM
  2. Check Engine Light
    Last Post: 11/01/2007, 05:57 PM
  3. Check Engine Light
    Last Post: 10/29/2007, 01:25 PM
  4. engine check light on
    Last Post: 09/15/2006, 01:20 PM
    Last Post: 06/28/2003, 10:52 AM
