Results 16 to 30 of 36
Thread: overheating with ac on ALL READY!!!
  1. #16
    Jun 2013
    2001 Silver 1221
    +1. Had the same issue last summer, replaced the clutch (AISIN FCG003 FCG-003@X09 from rockauto), kept the original fan. No signs of overheating, even in traffic with AC on when temp is in the 90s. The only complaint is that the fan is noiser than before, but I can live with that...
  2. #17
    Sep 2010
    1999 silver vx 0250
    ok pulling the electric fan,sucks because i really noticed a better throttle response..
    my old clutch is seized up so i will have to get a new one,good idea anyway as i read on line that fan clutch will lose rpms each year so seeing that the clutch is 15+ years old prolly needs replaced even if it wasnt seized up
    thanx everyone for all the input,you guys saved me alot off time and aggravation
    ill let ya know how it works out
  3. #18
    Back in 2001-2012 MANY of us VX owners were having the same overheating problem...went thru the steps you did, including the RD racing radiator, but many (myself included), found out it was the fan cluth and the fan blade. Isuzu redesigned the fan blade too.
    This thread is in second link eternal21 listed in post above:
    http://www.vehicross.info/forums/sho...avis+fan+blade
  4. #19
    Sep 2010
    1999 silver vx 0250
    ok new clutch installed with old fan blades
    no overheating at all but load as hell!!!
  5. #20
    Jan 2014
    2001, Foxfire, VX, 1132
    I'm sure it cools with the fan clutch! But I'm with you that clutch SUCKS horse power from what little HP these engines have! It seems no one looks at my posts.
    Electric fans will work, but it's not cheap! or universal. You can't just buy a fan & attach it & expect it to work. It has to have a formed shroud for the radiator to cool properly.
  6. #21
    Sep 2010
    1999 silver vx 0250
    mine did have a shroud and still didnt work
  7. #22
    Sep 2010
    1999,VX, 2477
    Thanked: 8
    Quote Originally Posted by vxfocus View Post
    Excellent! Turn up the music, you won't hear a thing
    Quote Originally Posted by ohiovx View Post
    I have a Ron Davis radiator and a Ron Davis custom fabricated shroud made specifically *for that radiator* with dual high flow electric fans and it still overheated.
    If there's a huge concern over the loss of the couple hp, just pick up a cold air intake or run a high flow (200 cel) cat.
  8. #23
    Jan 2014
    I'm not trying to be a jerk here guys, but if you have cooling problems with an electric fan & put a stock mechanical fan back on & it cools. That tells you it has nothing to do with the radiator. There was either an issue with the electric fan not flowing enough cfm, OR the fan & shroud are not matched to the radiator properly. If you get an electric fan that pulls enough air & a shroud like mine, it will pull just as much air through the radiator as a stock fan with a clutch.
    Don't know who Ron Davis is by the way.
  9. #24
    Sep 2010
    1999 silver vx 0250
    i kinda figured the the electric fan wasnt pulling the same amount of cfm's as the clutch fan,but ffdynamics wanted to know my vehicle info to size the right fan..
    i would like to go back the the electric fan if i could find the right one
    anyone know what cfm rating the stock fan is rated at??
  10. #25
    Ron Davis Racing Radiators, in Phoenix, AZ. Fast & Loud (TV show about Dallas based custom shop) uses RD radiators in all their builds.
    No, don't think you're being a jerk at all, we're glad it's working for you
    It's just several owners here have tried various electric fan set ups, without success. Eternal21 initially said he had good results with his (Post #92), but has posted in this thread above that it didn't end up solving it either. So your experience appears to be different than most others here that have tried it.
    I personally discussed it at length with the guru at Ron Davis, as I wanted to consider getting one, but he specifically advised against it and thoroughly explained his reason (in post #89). I even said I would get the custom made shroud if it would help with the electric fan set up. He didn't think it would.
    Another thing to note, is that during 2010, 2011 it seemed numerous owners here were reporting the same problem of overheating. Myself included. After many new radiators, both stock and RD Racing, and several electric fan installs, most still had the o/h problem. It seems that almost all of these owners eventually replaced the OEM FAN CLUTCH and it resolved the problem! Some tried non-OEM and reported they didn't work very well, but o/h resolved when an OEM was installed (VXorado),
    Here's the threads on the RD radiators in VXs and electric fans:
    The RD Racing Radiator increased cooling capacity by about 1/3.
    I just like looking at this gorgeous piece of work!
  11. #26
    Sep 2010
    1999,VX, 2477
    Thanked: 8
    I've already been through an FFDynamics as well. Worked well, but off-roading, the temp would start to creep to the point where I didn't want to chance it.
  12. #27
    Mine was also a FFDynamic fan... hmmm, maybe it's just an FFD issue? Inadequate CFM like OhioVX stated.
    I noticed my engine temp was creeping up on the interstate at 75 MPH cruising with the outside temp only in the 70's. I didn't want to chance keeping it installed for the summer and risk getting stranded.
    I'd like to go back to a electric fan as the throttle response was noticeably better.
  13. #28
    0.01% more noticeably better
    I worked the math in my head one day on my commute from hell. T'ain't much.
  14. #29
    Oct 2002
    01 Proton 1131; 01 Proton 0504; 00 Proton 0695; 00 Ebony 0285; 00 Foxfire 0032 Donor VX; Complete S/C Engine on Stand;
    Just wondering what a used Ron Davis radiator and shroud would sell for...
  15. #30
    Sep 2010
    1999,VX, 2477
    Thanked: 8
    Quote Originally Posted by siemprelisto View Post
    Can't comment on the radiator, but that's one mod I don't mind having. If you're interested in a RD shroud w/dual electric fans, hit me up. I have the receipt around here somewhere and can get pics if you'd like.
  1. overheating already
    By angeno in forum VX Talk...
    Last Post: 05/15/2014, 09:42 AM
  2. help overheating
    Last Post: 09/03/2010, 11:32 AM
  3. Getting the VX tow-ready
    By Travelin2 in forum VX Talk...
    Last Post: 10/07/2009, 10:52 AM
  4. Overheating
    By bobmumgaard in forum VX Troubleshooting...
    Last Post: 06/27/2007, 01:51 PM
  5. VX DVD is ready
    By tiggergreen in forum VX Talk...
    Last Post: 01/08/2004, 07:31 PM
