Windows have been working perfectly...until today.
Went to roll down the passenger side window and KA-Blooey (all credit for this technical term goes to T4B). Broke the plastic tab that holds the window to the glass. No problem since I have an SBC bracket for just such an occassion...except...when I pull the door apart one of the clips on the regulator that guides it up and down the center guide is broken on one side. When you pull the glass off of the regulator it swings away from the guide.
Before I pull the trigger on a new/used one please verify for me that this is the only fix for the center plastic being broken...
I have the piece if anyone has a fix...
Thanks for the reality check!
