Ham Radio Class - Denver
					Saw this posted on another forum.
There is a free ham radio class in Denver on April 25 9-noon. You can sign up here:
HamRadio
This is a much better trail solution than CB and with cheap handhelds now available for $30 that will easily outperform our large antenna setups. I signed up for the class. Colorado folks should consider doing the same and other state residents may want to look around locally to see if the same is available. The only negative issues are:
 1) it requires you to pass a test ($15)
 2) dissimilar equipment requires change and some cost
 3) group buy in needed so that majority can communicate
				There's no 'I' in denial.
