Results 1 to 4 of 4
Thread: Ignition cylinder stuck
    Feb 2012
    Looking to buy
    Fix my pump hanger issue and a new issue pops up...sigh....
    My ignition wont turn with the key off the lock position. Tried the second key and even had a buddy make one off the vin but no go. They open everything else. Steering wheel does not lock in place but the shifter does. Disassembled to the point of pulling the steering wheel now but havent done it yet. When I loosen the cable to the steering wheel lock the shifter moves fine so I'm figuring the cylinder is done. Tried all the tricks I can think of: Lubed it, banged it, hit the key, etc. but no help so to the point of drilling it out. My question is, has anyone drilled one out? If so, what size drill did you have to go up to, how deep, and what do I watch for? Did a lot of internet looking but was hoping for specific experience with the Vehicross.
    Thanks for looking!
    Have you tried turning your steering wheel from lock to lock?
    Feb 2012
    Looking to buy
    Yep, but will try again...anything to avoid having to drill
    Feb 2012
    Looking to buy
    Tmrw I start drilling the old ignition cylinder out...hopefully it all goes well. Ill take pics.
  1. Ignition shifter lock stuck
    By angeno in forum VX Talk...
    Last Post: 06/03/2013, 05:25 AM
  2. Ignition Switch Lock Cylinder...Urgent
    By TexasProton in forum VX Troubleshooting...
    Last Post: 12/03/2011, 07:52 PM
  3. Key stuck in ignition
    By Marlin in forum VX Troubleshooting...
    Last Post: 07/07/2011, 06:15 AM
  4. Master cylinder going?
    By MSHardeman in forum VX Troubleshooting...
    Last Post: 03/03/2009, 05:53 AM
  5. key getting stuck in the ignition
    Last Post: 08/03/2006, 07:44 PM
