Page 2 of 2 FirstFirst 1 2
Results 16 to 30 of 30
Thread: I need of a set of transfer case drop brackets.
    Jul 2014
    2001 Ebony Black #0691
    well I can deliver the beer... but if all i need are a set of springs for the rear, whoever offers the cheapest and ill buy em tonight.
    Jul 2014
    so a set of these is all i need to achieve a 3 inch lift (well of course torquing the torsion bars)
    http://www.independent4x.com/Isuzu-O...gs-_p_132.html
    I posted this at start of this thread for you......
    http://www.vehicross.info/forums/sho...913+experiment
    It has the answers you seek, for an OME coil spring lift...
    ...see pic below FROM THAT THREAD
    If you want 3 inches add spacers to coils.
    Jul 2014
    well Jo which springs would you pick if youre going with a budget lift. 912 or 913? I know this is probably obvious but I want the blessing from the VX gods...
    Jul 2014
    im also running on 275/65R/18 Nitto Terra Grapplers. And they take up the whole wheel well compared to the wheels on the picture above.
    Jul 2014
    im guessing 913 cause i would like it lifted and more level.
    If you are running 275/65R/18, which are approx 32 inch tires...
    ..you need to decide how much you want to lift.
    Thats a personal / aesthetic taste deal.
    You have to decide if its for 'looks'... or maximizing Off Road clearance.
    Below shows what 912's & 913's will give you.
    Lift with OME 913's with NO SPACERS = 1 3/4 in. lift
    Lift with OME 912's with NO SPACERS = 2 1/2 in. lift
    So, figure ot how high you want to go and buy the appropriate OME springs.
    If, after doing lift, you decide you want a bit more.. pop in 1 inch spacers.
    This isnt really a "budget" lift.. its just the best way to do it.
    And the bonus is the info and help here saves you MANY HUNDREDS.....
    ..cause you dont get reamed by Calmini, or your mechanic for huge time.
    Jul 2014
    either way the front will only go so high.
    Well sure...
    Quote Originally Posted by TEXAGGIE-VX-01 View Post
    BUT...the front will go PLENTY high enough for the tires you specified.
    Many , including me, run 35's...and a couple run even bigger...
    ........ and crank the front way higher than you'll require.
    With 32's you'll be well within the tolerance of the T/bar crank.
    Jul 2014
    well ladies and gents. I just placed the order for the 913's. went UPS ground on shipping. with a total after shipping at $218.57
    Jul 2014
    so at a later time will I be able to make the jump for 275/65R/18 to 285's?
    Yup...
    As explained... many already do / have.
    BUT... once you get past 33's... the diff drop is recommended
    Jul 2014
    i wouldn't go any bigger then the 285's as I plan to keep the factory rims... oh btw I picked up a full set of 4 rims off a 2000 Astral Silver car yesterday out of Killeen Texas for with decent tread on the tires for $175 total. god bless craigslist
    In need of a set* So im planning on having the 3 inch Calmini suspension lift installed on the VX @ 4WHEELPARTS of Austin TX. But the lift kit doesn't come with Drop Kerbs in Edinburgh down brackets.
    Depends. Do you have rear upper adjustable control arms to set your pinion angle?
    I tried removing my tcase drop, but got bad vibes when I tested it. I don't have adjustables so I threw the drop back on until I get some.
    Nov 2012
    Hey Xora, you are responding to a thread that's 8 years old. They probably got it taken care of by now.
    Cheers
    There's no 'I' in denial.
  1. My Diff Drop Brackets!
    Last Post: 06/08/2018, 07:42 PM
  2. Diff Drop Brackets
    By UWVX89 in forum VX Modifications...
    Last Post: 11/18/2012, 01:06 PM
  3. Diff Drop Brackets
    Last Post: 04/04/2011, 07:40 AM
  4. Diff Drop Brackets
    By ZEUS in forum VX Modifications...
    Last Post: 07/29/2008, 11:18 AM
  5. Differential drop brackets
    By Ascinder in forum VX Modifications...
    Last Post: 03/24/2007, 05:52 PM
