Results 1 to 10 of 10
Thread: High Output Alternator
    Apr 2011
    1999, Astral silver, VX, 1575
    Salutations,
    Thumbing through the threads on high output alternators, I didn't see anything recently covered. My alternator has seen its final days so I thought this would a good time to upgrade. I've done some web searches and I see that there are a few out there, but I'd like hear some personal feedback if possible. And is it possible to reman the OEM to a higher output as a cheaper route.
    Thanks for your time.
    "Remember Tonight... For It is the Beginning of Always." - Dante Alighieri
    Sep 2010
    1999,VX, 2477
    Thanked: 8
    Quote Originally Posted by Intrepid_Vanguard View Post
    Salutations,
    Check my build thread....start on post #7 and read down from there.
    http://vehicross.info/forums/showthread.php?t=25477
    Apr 2011
    Thanks for the imput. I had a look at the website earlier.
    Sep 2010
    1999,VX, 2477
    Thanked: 8
    Not a problem. I'm glad I went this route, and would do so again in a heartbeat.
    Oct 2012
    2001, Proton, 0586
    Can I ask you why you want to upgrade? Did you find your old alternator inadequate (prior to a point it started going bad)? Unless you have some unusual electrical system demands (massive sound system or LOTS of old style lighting), you really shouldn’t need to upgrade.
    And this is coming from someone who modifies and races most of his cars .
    Apr 2011
    Upgraded sound system and lights. I was also having an issue with RPM's jumping when I'd use my turn signals after 65 MPH with everything turned on. I want to see if that fixes it.
    Oct 2012
    2001, Proton, 0586
    I am not sure this will help you. A higher current alternator will put higher load on the engine. How is your battery?
    Apr 2011
    Battery has been upgraded as well.
    Mar 2012
    1999 Ebony Black (Runs great/Looks a lil less than great... but getting there!)
    160A installed here. Will review data from eBay on where I had purchased. Some friggin Californian if I recall.
    Always Forward,
    The Down to Earth Nurse
    Mar 2015
    Mechman alts. nuff said.
  1. High idle/ high power steering pressure?
    Last Post: 09/22/2007, 03:21 PM
  2. Replies: 7
    Last Post: 08/03/2007, 05:33 AM
  3. High Output Alternator : ?
    By biju in forum VX Modifications...
    Last Post: 11/20/2006, 08:26 PM
  4. High output alternator
    By Rickster in forum VX Modifications...
    Last Post: 03/26/2005, 08:58 PM
  5. Replies: 7
    Last Post: 04/04/2004, 08:24 PM
