You shouldn't just "disconnect" your EGR valve, if you want to disable it.   You need to block the flow between the exhaust and intake.  This can be done with a plate or with a simple gasket that lacks holes for exhaust gas to travel.  The simplest way to make such gasket is to cut one from Coke can!    This will surely cause a permanent CE light.
I do not know what you are "feeling", it typically take 10% of power to feel the difference without using instrumentation, and I can't imagine EGR making THAT much difference.
