OK so here's the story about the problems with my VX.
Monday morning going to work it starts shifting very hard and engine check light comes on and TOD check light keeps coming on and off. So go back home idling at 3000rpms check codes P0122 Throttle Position Sensor/Switch A Circuit Low Input. Replace it same problem high idle but TOD is ok. Replace ICS with battery disconneted for a hour. Idles ok for 30 sec and goes to 2500rpms. Take it to a buddys auto shop he is getting P0123Throttle/Pedal Position Sensor/Switch "A" Circuit High Input. Replace TPS again now still high idle and P0101 - Mass or Volume Air Flow Circuit Range/Performance Problem changge that and its ok till a test drive and in a mile back up to 2500rpm. So he thinks its Power Control Module because after messing with senors ok till driving again. So I pick up VX and idle is ok but he says will come back I make appt at dealer to check it but on the way no Engine lights or problems. Drove it 40 miles yesterday all good. Going out again today but need to go 80 mile round trip to work tommorow and am worried I will get stuck. And thats the shorted verison!
Any ideas on whats going on here
Steve
