Results 1 to 6 of 6
Thread: Questions ...
    Jan 2015
    1999 Ebony VX, 0209
    Thanked: 19
    Questions ...
    Hello again,
    I have a couple of questions I haven't been able to ferret out.
    1) What is the "Iron Man" package? What does it include (or exclude)?
    2) Just how well does the TOD system work off road compared to say a "normal" 4wd transfer case?
    3) Does the TOD system split left/right as well as back/front for delivering power?
    4) I have found a locker for the rear, can you get one for the front? I am assuming with enough time or money or a cutting torch anything can be made work
    Thanks for any information.
    Jul 2014
    2001 Pearl White Vehicross 1455
    Reply
    Quote Originally Posted by Thelgord View Post
    Hello again,
    1) What is the "Iron Man" package? What does it include (or exclude)? That's a little confusing because some Vehicross registrations are labelled as Ironman versions. In theory, All "badged" Ironman's were white, had Ironman badging on them and the seats have Ironman labeling as well. I don't think there was any other extra equipment that wasn't available on any Vehicross.
    Depends upon the manufacturer of the transfer case your comparing. Some of the modern versions are pretty trick. The TOD is nice because it's a full time operation that doesn't need to be engaged or disengaged. It's automatic.
    Just front to rear. Rear diff is an LSD.
    What locker did you find for the rear? There's a couple of companies that make them for the other Isuzu models but the spline count is wrong for the Vehicross.
    reply
    Current caretaker of The elusive 2001 "Pearl White" VX - The last one.
    1988 BMW 325ic
    2001, Ebony Black, 1153
    There are lockers available for the VehiCross. Both Arb and Aussie lockers have been available at some point. Contact Independent4x or watch Pirate4x4 for availability:
    http://www.independent4x.com/Isuzu-D...ials_c_80.html
    Jan 2015
    1999 Ebony VX, 0209
    Thanked: 19
    @ahdoman as LittleBeast said, ARB and Aussie lockers are available. I actually found them on Ebay. I am just not sure if it is compatible with the front diff.
    I had front & rear ARB lockers installed. Part numbers should be in my build thread.
    Front and Rear Aussie lockers are available for sure....
    ...I have them
    Jo
  1. more questions please
    By sopo in forum VX Talk...
    Last Post: 09/17/2013, 08:13 PM
  2. Just some questions
    By stingray in forum VX Talk...
    Last Post: 01/31/2010, 05:18 PM
  3. Questions
    By Johnny108 in forum VX Modifications...
    Last Post: 04/07/2008, 08:15 AM
  4. 4wd Hi questions
    Last Post: 11/22/2004, 05:27 AM
  5. Questions
    By Apostle in forum VX Talk...
    Last Post: 10/06/2003, 11:44 PM
