Originally Posted by
8695Beaters
1) The ABS light and TOD CHECK light were on when I got in. We ended up replacing the ABS fuse and the TOD light went off and I noticed the front wheel indicators began changing (instead of showing full RWD). I understand the TOD and ABS share sensors, so fixing the burned out fuse would explain why the TOD came back. But there's still no ABS (or at least the ABS light was still on. I did not get the ABS to engage nor did I lock the tires. Just wasn't slick enough). I'm hoping it's just a sensor, but after doing a forum search it seems the ABS modules can go on these too. What are the chances it's the ABS module and not just a sensor? Or with the fuse back in place, does the ECU need to be scanned and reset to get rid of a fault code?
My ABS light was due to the module going out. I had it rebuilt for about $100 which is less than any of the sensors will cost you if you have to buy them new. They are available from salvage yards from other Isuzus with ABS. You can find the information on the rebuild here on the forum. The shop I used is in TN and I just removed the electrical part, sent it off, put it back when the repaired part was returned. Vehicle can be driven with the electrical part removed and no need to flush the brakes once it's put back in.
Many of the members here have had that issue as it is a common problem. Some fix it, and some don't. Just depends on your preference for ABS or not.
