Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Thread: Full time TOD switch
  1. #16
    If simply disabling the TOD for a while is the real goal...
    .... simply unplug it underneath the passenger seat.
    Pull out both grey multi connectors .... and TOD is off.
    Jo
    Apr 2014
    2001, yellow, vx,0838
    No I want to make it 50/50 ratio all time when I want it to. However I'm going to do a 5speed swap from a 98 trooper.
    If you are just trying to force the TOD in 2wd mode you put a switch inline with the light blue wire at your TOD ECU. The switch brakes the connection and you have 2wd restore the connection and restart the VX and TOD is restored. You will get a fault flashing on the TOD display unless you do the resistor mod.
    http://www.vehicross.info/forums/sho...=tod+blue+wire
    That others may Live
    Warrior Automotive
    Jake
  1. Mode Selector Switch & Power Switch
    By ahdoman in forum VX Troubleshooting...
    Last Post: 11/20/2014, 11:34 PM
  2. Heater/aircon fan on full all of the time
    By David Wiltshire in forum VX Troubleshooting...
    Last Post: 07/04/2013, 09:28 AM
  3. VehiCROSS: AWD or Full-Time 4WD
    Last Post: 06/16/2008, 08:09 PM
  4. Full Brush Guard.....
    By Lizardmen3477 in forum VX Modifications...
    Last Post: 08/27/2007, 01:19 PM
  5. Can The VX be towed full time?
    By crfandy in forum VX Modifications...
    Last Post: 10/23/2005, 07:32 PM
