Results 1 to 15 of 17
Thread: Full time TOD switch
    Apr 2014
    2001, yellow, vx,0838
    Has anyone ever tried to do a full time tod switch. i have searched the site and found nothing.
    That others may Live
    Warrior Automotive
    Jake
    Nov 2014
    1999, white, ironman, 1252
    I have one, but it was done by the previous owner. It helps me save lots of gas!
    Quote Originally Posted by Otwobme View Post
    What are you trying to accomplish?
    Others may have done what you're wanting to do, but called it something different.
    Hope you had a great Christmas Jake.
    Jun 2007
    2001, Proton
    how much does it save?
    Quote Originally Posted by JayDallas View Post
    What is your mpg in the two different modes. I am surprised if it is a bunch since you still have the same aerodynamics and the weight which is 99% of the issue.
    Carter Pewterschmidt
    Sep 2014
    2001, Foxfire Red, 1283
    Gear Ratio in the differentials is a big factor 4.30, that is a low gear.
    Our tod is full time...unless your in 4lo.
    Gas savings will not be that substantial...others have disconnected their tod and said if there was any savings it was minimal. You still have the same weight, same aerodynamics and as your tires roll your still turning the cv's, shafts, gears etc in the front end. I have manual hubs, drive daily with them unlocked and have not noticed much in the way of mpg changes...but it does save a little wear and tear on the front end components.
    And if it is a ToD disconnect you are looking to do there are several threads on here about that. It has and can be done.
    Nov 2014
    Well, you guys make a good point, saving can be relative, my savings is between 2 - 3 mpg. To me that's makes a big since I can drive up to 150 miles a day.
    Apr 2014
    I want to set the tod up so I can turn it on full time 50/50.
    As you know right now it's 85/15 until the front starts to slip then the tod kicks up and starts putting more power to the front. Like I said I would like the option to make it 50/50 all the time until I want to turn it off. The weight distribution, aerodynamics and fuel does not matter in this situation. It's just so I can turn on the tod to 50/50 anytime I desire
    Apr 2014
    This is perfect, thanks john. I'm going to do this mod. As well as a tod off switch.
    Thanks again
    No problem, I considered doing this years ago and never got around to it. Seems like a great mod with a very detailed how-to. Hopefully the ECU pins aren't different on the VX vs. 02 Trooper.
    Jul 2013
    1999 Ironman hopeful
    Does anyone have a clue as to how one would wire in a 4wd button out of a Trooper, into our VX? I have a transfer case that has the chain skipping teeth and im trying to prevent further wear and tear until the weather clears to swap the case. I understand I can disconnect it manually but I want this button just in case and so that I can put manual hubs on later.
    Apr 2014
    Quote Originally Posted by Audacity View Post
    Just to let you know I have two TOD's transfer case I will sell one to you. Just pm me
    Nov 2012
    If you are just trying to force the TOD in 2wd mode you put a switch inline with the light blue wire at your TOD ECU. The switch brakes the connection and you have 2wd restore the connection and restart the VX and TOD is restored. You will get a fault flashing on the TOD display unless you do the resistor mod.
    http://www.vehicross.info/forums/sho...=tod+blue+wire
    There's no 'I' in denial.
  1. Mode Selector Switch & Power Switch
    By ahdoman in forum VX Troubleshooting...
    Last Post: 11/20/2014, 10:34 PM
  2. Heater/aircon fan on full all of the time
    By David Wiltshire in forum VX Troubleshooting...
    Last Post: 07/04/2013, 08:28 AM
  3. VehiCROSS: AWD or Full-Time 4WD
    Last Post: 06/16/2008, 07:09 PM
  4. Full Brush Guard.....
    By Lizardmen3477 in forum VX Modifications...
    Last Post: 08/27/2007, 12:19 PM
  5. Can The VX be towed full time?
    By crfandy in forum VX Modifications...
    Last Post: 10/23/2005, 06:32 PM
