 TOD, 4WD and other off-road info
					OK, so now that I've owned Pearl for a couple of months I'm still trying to get my head wrapped around how the TOD vs. 4L works for off road. (My past experience with 4x was a 98 Toyota Tacoma with locking front hubs). Since I'm starting to do some off roading (and with any luck I'll be able to attend Moab) I need to fully understand the VX system. The owner's manual is very vague. Please correct me on any of my assumptions;
- If I understand correctly; the TOD system only operates when in "high"? Does it do individual wheel control or just front to rear ratios?
- Is there a time, when off roading, when it's better to leave the VX in "high" and let the TOD do the work?
- When the VX is in 4L it locks the transfer case but because the diffs don't lock, the right front wheel and the rear left will still spin freely if you don't have traction (for example if the front left wheel and the right rear are on the ground then the other wheels that are in the air will spin and you'll go nowhere?)
- Only the rear diff is LSD?
- Has anybody ever done a writeup for installing lockers on the VX? (I did a website search but found nothing).
Thanks everybody for your patience with my questions. I'm torn with this because I want to keep Pearl in good shape because she is so rare but I also want to use her for what she was built for. I've already fabricated a skid plate that covers the transfer case and I'm looking at buying sliders. What I really need is to find a VX that's got hail damage, chop the top and just build a VX-O2!
				Current caretaker of The elusive 2001 "Pearl White" VX - The last one.
1988 BMW 325ic
