Yep... what Mark said. You have more than enough torn down on the front side. Cut the band on the boot, pull the boot back, use brake cleaner to clean out most of the greese. Then locate the "wire" ring in the groove on the race about a 1/4 inch in. Pop it out with a small screw driver and the shaft, cage and balls will slide right out.
