Remove hub cover
Retaining clip is about 1/4 inch in on the spline shaft in the center
You can then remove the hub
Also be sure to remove the retaining ring on the back side of the hub. It is a wire ring in the ball race that sits in a groove. You can feel it with your finger. You can remove it with a small screw driver.
