But without the lower balljoint unbolted from the control arm, how do you have enough room to split the inner CV from the green cup?
From my experience, there's not enough width (green cup to spindle) to pull the CV from the green cup without the ball joint disconnected. I always removed the hub and lower BJ, removed the boot clamp & retaining ring on green cup, pulled the spindle away & upward (seperating the green cup & CV), moved the free end of the half-shaft toward the side and finally pulled the halfshaft from the spindle.
If there's an alternative method, I'd love to learn it! It would save a bit of time if you don't have to remove the lower ball joint.
