Results 1 to 6 of 6
Thread: CV Axle Shaft
    Nov 2014
    2001, white, ironman
    CV Axle Shaft
    Hello everyone!
    I've got an issue here with my VX. Trying to replace the CV axle shafts, the entire shaft. I've seen the how to's to remove just half the shaft. However, I can't seem to move past this point in remove the shaft that goes into the transmission. Both sides, the boots have been broken since I got the car.
    The reason for this is they are clicking when turning and also now it seems to make a clank noise (as if something skipped), when the AWD/TOD system disengages/engages around 30mph (this may be something else though, hence the reach for help here). I've been putting off to look into another issue that's been present for some time. That issue is as if the tires are different sized and the AWD/TOD system makes a humm or med/high pitch sound when driving, most of the time coasting. Which I believe gave way to the clank noise I am trying to resolve.
    You'll have to drop the diff if you want to remove the entire axle shaft.
    Nov 2007
    1997 SILVER
    The TOD system is very sensitive to tyre rolling diameter.
    Not only must all 4 tyres be the same size, they must be the same amount of wear, and the same pressure within a few PSI.
    Mile High is correct about removing the complete axles - first you have to drop the diff down. Most only replace the CV joints from the green cup out, provided the green cups are in good condition.
    PK
    Nov 2014
    I see, do the inner axles that go into the differential wear down quickly in this condition? Also, What would explain the clunk noise when the TOD %100 engages/disengages? To replace the shafts, it would be outer axle shafts?
    With regard to the axle shafts....
    I'd suggest only doing the outer .. "Half Shafts" initially.
    Basically from "Green Cup" outward on each side.
    This is usually the culprit with clicking etc on tight turns...
    ...and also when TOD kicks in...as this loads them up and
    cause binding/clicks not always noticeable when TOD is
    not in "action"
    When doing this, check condition of inside of "green cups"
    for excessive wear and fit of new races.
    If OK.. you should be good..if sloppy... entire new axles may be needed.
    What replacement axles are you using...some are good..
    ...some NOT so much!
    The Sur Trac replacement axles are very good if not used for aggressive
    off roading.
    The race/balls and tolerances are up to OEM spec.
    Cheers
    Quote Originally Posted by Merrell90 View Post
    The green cup is actually the outer race of the CV joint. If you're getting the clicking sound then it's likely that the green cup has some divits worn into the grooves where the bearings ride (that was my finding on a statistical sample of one).
    Most people end up just needing to do a good cleaning - new grease - new boots ... but a few of us weren't so lucky. I was able to find a shop that ground out the grooves on the green cup and then installed oversized bearings. That worked fine for me. Another member found a shop that filled the grooves with a welder and then machined them back to OEM tolerances. That worked out well too. Everyone else that had excessive wear of the joint either went with SureTrac shaft replacements or were able to source a set of used shafts from the boneyard.
    My recommendation is to just try the boot replacement first. Even if the clicking persists, then you've bought yourself some time to source new shafts.
  1. Front drive shaft
    Last Post: 02/17/2017, 06:02 PM
  2. ABS and drive shaft U joints
    By kitman3 in forum VX Troubleshooting...
    Last Post: 10/23/2013, 10:03 PM
  3. Inexpensive CV Axle Outer Half Shaft Installed
    By Spyder in forum VX Talk...
    Last Post: 12/21/2012, 08:29 PM
  4. Broken Axle Shaft
    By angeno in forum VX Talk...
    Last Post: 05/30/2012, 10:00 AM
  5. CV Shaft removal?!
    Last Post: 02/03/2004, 08:07 PM
