Need u to c
					MATT!
Had this same issue at or about 10,000 mi maintenance mark (this past few weeks or so).
The gas smell on mine felt like it was exhaust bound but really came from under the hood. It was a loose psgr side hose to the fuel rail PLUS the fuel rail was a lil bent pulling my psgr side middle cyl AWAY from the manifold!
I pulled the manifold and retourqued to BOARD specs (13 ft. lb NOT 18 ft. lb per the manual!!!) I also replaced the Injector O-Rings (soak the upper ones in clean motor oil before you install them!!!!)
I used a Victor Reinz Manifold gasket (Fel-Pro was "good enuff garbage!" up until that point) and I used Nippon Reinz O-rings.... I'm between 16-18 MPG now and I got a ton more torque/acceleration out of her to the point I'm shopping H3 manual trannys now for next the swap/upgrade.
I hope this helps you
PS TONY! That damned flex coupling on the driver side exhaust... oy don't even get me started man!
				Always Forward,
The Down to Earth Nurse
