Results 1 to 11 of 11
Thread: Slow/dead windows
    Oct 2003
    2000 Kaiser
    Slow/dead windows
    Ok, so driving down the road, 20 below outside (or felt like it)
    rolled the window down for something, and when i tried to roll it back up, it went extremely slow then not at all, so i lowered it and tried again
    not until the third time when i assisted it with hand, that it went back up
    no problems since, every now and then, even before that i would get a semi slow roll up.
    what can i do to fix this? was thinking a stronger motor, but then thought about the battery.
    EDIT: i did not notice any binding, i already know about that problem. they just went slow for a bit
    Jul 2002
    99 Ironman
    Do a search on window problems. I'm sure you'll be reading for hours. Best advice , if you live in a warm climate "just break-um"...
    Feb 2003
    hmmmmmmmmm.........
    if the window is going up slow or not at all...either the motor is out or it is binding!!!
    Oct 2003
    2000 Kaiser
    thought about the binding, but its rare that it happens.
    motor seems fine.
    Does the motor draw directly from the battery? i do recal it was right after starting it up, so that made me think battery is kinda weak
    guess ill do the fix, see what happens then
    '01 Ironman
    window regulator? I have not had the actual binding problem that people have (I had what you described) but I have had both window regulators go out and my drivers side just went out again.
    I had my regulators replaced, windows go up and down fine now :-)
    - To Err Is Human, To GET SOME is Divine -
    Thanked: 7
    Lubricate the tracks with silicon at intervals as an added preventative.
    Anita
    2000 Ebony #263
    AnitaProtich.com
    Oct 2003
    99', Astral Silver, 0430
    I think you have binding that you are not so aware of. I have some random binding in the summer, but in the winter its like the binding changes into more of a slow down. If you pull them up that always helps, as Anita said silicon spray lube in the tracks also works quite well (be cautious of overspray getting on the glass, its a pain to clean off), but I think the real window fix is Moncha's window fix walk through. I think he is dead on with his solutions and am looking forward to trying it out. Now if it would just stop snowing i might actually do it.
    Heres the link: [URL=http://www.vehicross.info/forums/showthread.php?s=&threadid=1180]
    2001 Proton VX #0662
    Spray silicone from the auto parts store on the rubber tracks all the way around the frame. That fixed my slow windows.
    Canadian VXer!
    Mar 2003
    2001, Dragon Mica Green, 0945
    Seems that the VX has a design flaw with the windows. A few people that I know have already had the driver and passenger side replaced...more than once!! My passenger side got replaced this summer, and my driver side is a little slow. Good luck!!! it is covered by the warranty!
    Stacey
    2001, Black/red VX
    I just had both the passenger and Driver side motivators replaced.
    Dealer first replaced the seals thinking that was the problem (even though I told them it wasn't). This did not fix it. Brought it back a week later to yell at them again, then they replaced both motivators. Windows go up fine now and quite a bit faster. So, I think the motors in both were dying. (death of motivator caused by slight binding I suspect) I am going to try that silicone lube thing mentioned above just to be safe.
    Everytime I take my VX to the dealer to get something fixed they seem to break something else.....like the door trim panel...
  1. Going Drag racing in the slow lane!
    By ohiovx in forum VX Talk...
    Last Post: 11/07/2015, 12:20 PM
  2. Driver's Window slow to raise
    By curiouswords in forum VX Talk...
    Last Post: 05/11/2006, 10:41 AM
  3. slow starting
    Last Post: 03/09/2006, 07:13 AM
  4. Tire with slow leak
    By WyrreJ in forum VX Troubleshooting...
    Last Post: 11/25/2003, 11:27 PM
  5. Vmag dying a slow death?
    By Panther_Black_VX in forum VX Talk...
    Last Post: 05/28/2003, 10:31 AM
