Results 1 to 10 of 10
Thread: seatbelt retractor
    Jan 2010
    2001 black 1145
    seatbelt retractor
    My drivers side seat belt retractor does not work to well. Anyone undertaken fixing or replacing this?
    Seems like a pain in the a.... job.
    Jul 2012
    I have the same issue in mine and accidentally slammed the door on it several times.. I haven't had it repaired yet, but it's on my long list of 'to-do' items for the vx.
    2001, Ebony Black, 1153
    Haha, I had the same problem, all I did was switch the passenger and drivers side belt mechanisms. They are exactly identical, and now I only deal with the bad retraction when I have passengers.
    Jun 2007
    2001, Proton
    same problem here
    Had the issue almost from new.
    Carter Pewterschmidt
    Sep 2003
    1999, Black, VX1, 0813
    I get it occasionally... would be curious if there's a good fix.
    you rat bastards. Never had an issue till you posted about it!!!
    Jan 2010
    2001 black 1145
    Was it a tough fix to switch the passenger and drivers retractor?
    X2
    I've slammed the door on it a few times, so I've gotten into the habit of being very careful to make sure it fully retracts. I've had to pull it almost to the limit on a couple occasions to get it to retract.
    And then there's the opposite... it locks when I come to a stop on a downhill intersection, and I can't lean forward to look around the inevitable bushes planted right on the corner!
    Gregg
    2001 Proton Yellow #1379
    Jun 2007
    2001, Proton
    I actually
    Quote Originally Posted by Cobrajet View Post
    X2
    have to feed it into the retractor bit by bit, slammed it in door more times than you can count,
    Nov 2010
    2001 Dragon VX
    Ditto. So it's not just me. It's an intermittent thing and I can go weeks with no problem and then it flares up again. I just usually pay it out carefully and let it slowly reel in.
  1. seat belt retractor
    Last Post: 05/10/2015, 04:29 PM
  2. rear seatbelt replacement idea
    By blujfan9293 in forum VX Talk...
    Last Post: 06/30/2009, 05:12 PM
  3. Seatbelt spring replacement
    By UtahVXer in forum VX Troubleshooting...
    Last Post: 03/22/2006, 09:25 AM
  4. Help-seatbelt problems
    By Kahuna in forum VX Troubleshooting...
    Last Post: 05/28/2004, 04:36 PM
  5. Probably the best seatbelt
    By JAG! in forum VX Talk...
    Last Post: 04/26/2004, 11:50 PM
