Results 1 to 4 of 4
Thread: new brakes
    2001, Kiaser Sliver, 0282
    new brakes
    Did a brake upgrade this past weekend, rotors, pads, lines, flush and bleed, repacked front bearing grease. Only issues were getting the bearing retainer off, needs some special tool I did not have. tapped/spun it out with a screw driver, carefully but seemed to work ok. and the nut on the 5th line was loose from goodridge and was leaking, once I tightened it up, all is well.
    Big improvement. much more confidence in them now.
    From JC Whitney ($430):
    Centric Slotted Rotors, CE126.43013SR, CE126.43013SL, CE126.43015SR and CE126.43015SL.
    EBC Greenstuff 6000, DP6973 and DP6974.
    From Amazon ($138):
    Goodridge 23042 Brake Line kit
    From O'Reilly Auto Parts ($40):
    National Oil Front Bearing Dust Seals (qty:2) 710168
    Big bottle of O'Rilly brand Dot3 brake fluid
    3 cans brake cleaner (green)
    1 tub of bearing grease (red)
    NOTE: if your lifted, the SS lines might be too short.
    Jul 2012
    Sweet! How long did it take you to replace all the rotors and brakes? I just bought a set and hope to get them replaced soon after I get them home.
    how long
    it took about 5 hours, and I hade a master mechanic helping, actually he did most the work. he's a great friend of mine, helps me all the time.
    Jul 2012
    Ah crap. Well I guess that means it'll be a weekend long project for me! Woohoo!
  1. Brakes
    By tom4bren in forum VX Troubleshooting...
    Last Post: 05/16/2015, 08:41 PM
  2. Brakes need to be done
    Last Post: 05/07/2010, 12:26 PM
  3. New brakes!
    By erland in forum VX Modifications...
    Last Post: 11/13/2009, 01:05 PM
  4. Me or the brakes?
    By cyronman in forum VX Talk...
    Last Post: 11/28/2006, 09:58 PM
  5. Brakes
    Last Post: 05/03/2006, 10:37 PM
