Results 1 to 8 of 8
Thread: Simple Lifting
    Sep 2010
    1999, yellow
    Simple Lifting
    Hey,
    One question to all of you guys:
    I have Japanese Version VX and wanna lift it but with some simple ways, like pushing below the spring or whatever. I don't wanna use heavy lifting kit, so can you suggest any methods apart from tires/rims?
    Thanx
    The most common approach to lifting is to install replacement rear coil springs for the lift in the rear & simply crank down on the torsion bars for the lift on the front.
    It is easily accomplished in your driveway with simple hand tools & a jack. I had to actually use 2 jacks when replacing my coils springs (one to lift the vehicle & the other to flex the suspension enough to remove the spring).
    Here's the How2 on adjusting your torsion bars.
    These coils will give you about 3" of lift (also available from Rocky Road Outfitters).
    http://www.independent4x.com/Isuzu-O...gs-_p_132.html
    There have also been some members who have used coil spacers rather than replacing the springs themselves ... but your springs are 15 years old so it would probably be a better option to replace/upgrade (just my $0.02)
    Sep 2010
    1999, yellow
    Thank you, really helpful tips. But will this affect shocks? they will not be in normal position right?
    Sep 2010
    1999, yellow
    and any issues with handling?
    Sep 2010
    1999, yellow
    Any sites for coils spaces?
    2000, Ebony, VX, 0370
    Thanked: 12
    Vaso, the shocks should be in the normal position, but it does extend them a bit. If you have stock shocks there is enough travel in them to handle the lift. When I lifted mine (more precisely when Jo, Dub and Jay lifted mine) I did notice a little difference in the handling. Obviously you're sitting a little higher off of the ground so your center of gravity is a little higher so the VX wants to roll a little bit more in hard cornering. I also noticed a bit of dive under hard braking with the lift (I initially kept the stock shocks on), but not anything scary.
    Independent 4X4 sells coil spacers if you would rather do that instead of getting new springs. http://www.independent4x.com/Isuzu-B...ane-_c_32.html I have a set of their 2" spacers and a set of taller springs (not installed together). The 2" spacers with stock springs give you about the same amount of lift as the taller OME springs. http://www.independent4x.com/Isuzu-O...gs-_p_132.html
    Here's a great thread to read through: http://www.vehicross.info/forums/showthread.php?t=15476
  1. Simple Genius
    By dietz99vcross in forum Chit-Chat ...
    Last Post: 02/21/2014, 06:26 AM
  2. Simple Question
    By VX MileHigh in forum VX Modifications...
    Last Post: 10/16/2012, 03:07 PM
  3. Simple, innane problem..
    By Grif in forum VX Troubleshooting...
    Last Post: 08/23/2009, 10:43 PM
  4. Simple Lift Questions
    By Grand_Canyon_VXer in forum VX Modifications...
    Last Post: 10/29/2007, 01:52 PM
  5. spark coils?, simple question..
    By Maverick in forum VX Troubleshooting...
    Last Post: 03/04/2004, 10:42 AM
