Results 1 to 12 of 12
Thread: Spark Plug Update
    Sep 2014
    2000, Black; 2001 Ironman
    Spark Plug Update
    So after reading several threads about spark plugs, I was wondering what you all are using now. Since, most of our VX's are well over 100K, what are the latest updates and suggestions?
    Sep 2014
    Anyone?.......Bueller?
    Jul 2009
    ...Bueller? Sometimes answers don't come quickly but at least on this forum they usually come. You musta pulled a stumper there. I believe the mighty VX came with Denso K16PR-P11 plugs gapped at .040 inch. Now Denso PK16PR11 Double Platinum plugs may also be used but just remember that they are not a high performance plug, just a high mileage plug, as in long-life... I have seen them both listed as Platinum plugs, but I believe the K16's are Iridium. Champion has their RC10PYP4 available but I think I'd steer clear according to reports.
    Speaking of reports, it occurs to me there was a discussion either here or over on The Planet about our little beasties having some sort of sensored ignition system that required the use of OEM Denso plugs. Not sure about that one but it bears mentioning...
    Vixer Fixer
    Jun 2007
    2001, Proton
    as far as I know
    that must have been the planet as I have no recollection but we have had spark plug discussions I would suggest using the search function
    Carter Pewterschmidt
    Aug 2005
    1999, silver, 0887
    How about just cleaning and reinstalling the OEM"S? I've done that and am at 170K.
    Nov 2012
    Our VX's have spark plugs? Who knew?
    There's no 'I' in denial.
    Sep 2014
    I think they are the red things on top of the air cleaner...?
    Jul 2010
    1999,silver,VX,0118 & 1144
    I thought it sparked from the lack of oil in cylinders....
    Mar 2015
    I'm going with NGK plats. My gut instinct is to use NGK's on Japanese vehicles. We'll see how it goes.
    1998 S10 4x4 Pickup & 1977 Porsche 911 Targa
    I use NGK solid copper on my old Porsche, a good brand.
    1998 Chevy S10 4x4 & 1977 Porsche 911 Targa + Hovercraft
    '01 Ebony #0939
    Platinums, Iridiums, etc, all sound impressive nowadays, but be sure to get a plug in the recommended heat range (hot, cold) originally specified for the VX. The guys at your local Autozone, O'Reillys', etc will usually be able to look that up and help you go from there.
    I tried one of the latest and greatest in my car for awhile, but was never really satisfied that they performed any better or lasted any longer than the stockers. I recently changed back to the original type, the car is running smoother than it has in quite awhile, and the iridiums I was trying didn't have that many miles on them.
    So I put some Denso Iridium Twin Tip plugs in the VX...runs good but gas mileage took a big hit..dropped almost 2 MPGs.
    Thinking about going back to the Denso PK16PR11s gapped at the factory .04 recommendation and see if my mileage returns to normal.
  1. Spark Plug Wires 8mm
    By isss in forum VX Modifications...
    Last Post: 05/13/2017, 05:54 AM
  2. Spark Plug Install
    By Mile High VX in forum General Tips...
    Last Post: 04/13/2010, 09:05 PM
  3. Coolant in my spark plug
    By jdm monkey in forum VX Troubleshooting...
    Last Post: 11/28/2008, 01:12 PM
  4. Oil in spark plug well
    By ojmagg in forum VX Troubleshooting...
    Last Post: 04/24/2008, 12:47 PM
  5. Spark Plug Torques?
    By xdfarrx in forum VX Troubleshooting...
    Last Post: 03/25/2005, 09:49 AM
