Earlier this week my transmission started hesitating/stutter then slamming into 3rd gear. I checked the fluid lvl, when cold, and it was exactly at the low line. When it was doing this the gear indicator lights started flickering. "D" has always been out, i found out when i went though the gears manually. Now it isn't doing this going into 3rd, but 2nd, and when i slow down to a stop. I immediately took it to my shop, they pulled the codes and nothing related to the transmission or TOD showed up, just the O2 sensor i've known about. could this be trans, TOD, or computer issues?
Using search some one said that the "trans mode switch" can cause the dash light issue. is that expensive?
Please tell me its something cheap! i just got a job after 10 months of looking and get my first check Friday.... i know where its going :/
on a side note, ive been using AMSOIL for the engine with a 25K oil change ive burned only about 1/2 quart total! Yes i check it regularly.
