Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
Thread: Running staggered tires
  1. #16
    Yea..NO...not in theory..not even in practice !!
    To make the transfer case/TOD work in harmony ...
    ...front AND rear diff need to be equal.
    AND..all tire sizes need to equal.
    You have a VERY limited set of options of diff gearing on the 10 & 12 bolt
    Isuzu diffs.
    ( so..the "matching the ratio"...is not possible..you get as close as you can!)
    I run 4.77's..It close! for my 35's..but could be better!
    If you have different diff front to back..
    ...you"ll
    (A) explode the TOD..
    ..and
    (B)..grenade the transfer case...
    and
    (C) never get going!..at all!
    Please ...do correct me if I'm wrong..
    .....but I have re-geared several VX''s
    I think I have this right
    Jo
    Jul 2013
    01,Victory White Ironman #0549
    Hey All,
    So in Short 235/45/18 & 255/45/18
    Will have different diameters.
    I thought just the width would be different.
    I just want to run a little bit wider in the rear then the front.
  3. #18
    Quote Originally Posted by VehiCrow View Post
    Hey All,
    Definitely not the same diameter. Check a few different tire spec sheets on tirerack.com, and you can find out which tires will have the same diameter.
    One I checked:
    235/45/18 = 26.4"
    255/45/18 = 26.7"
    By comparison, the stock Bridgestone Dueler 245/60R18 is 29.7".
    Gregg
    2001 Proton Yellow #1379
  4. #19
    285/65 18 is 32.6" diameter with a width of 11.22".
    265/70 18 is 32.6" diameter with a width of 10.43".
    Not sure what might be available in these sizes but the calculator I used said they were the same diameter.
  5. #20
    Jul 2013
    Hey guys thanks for the info.
    I guess I will have to do some more digging to match diameters.
    Thanks again
  6. #21
    2001 Proton VX #0690
    Quote Originally Posted by Starglider View Post
    b) I just remembered that TOD uses individual wheel speed sensors, not drive shaft sensors, so it would still see slip and constantly engage.
    I'm not sure this is true. There are wheel speed sensors, but they only feed into the ABS system. I'm pretty sure the TOD speed sensors are completely separate and only on the drive shafts, and it is only able to detect front/back differences.
    Doesn't change the fact that it is probably a bad idea to run different sized tires! I'd be curious if tires the same diameter would work okay, though... I just wouldn't be curious enough to do it on MY VX.
  1. Running hot?
    By angeno in forum VX Talk...
    Last Post: 08/07/2013, 03:01 PM
  2. Replies: 11
    Last Post: 11/05/2012, 01:22 PM
  3. cupping tires.. those running 285s
    Last Post: 12/08/2009, 07:53 AM
  4. Anyone running ARs?
    Last Post: 05/17/2006, 10:27 AM
  5. running hot
    Last Post: 05/11/2006, 08:28 AM
