Results 1 to 15 of 24
Thread: HUB & race problems - sourcing issues
    2000 IronMan #11
    Mechanic has my passenger side ball joints on but said when installing the new bearings that my hub is bad.
    He said it allows the race for the bearings to move too much/is loose.
    Have you heard of this before? Now he cant source another hub and does not want to burn new bearings in this race.
    2000 IronMan #11
    Any info?
    2000 IronMan #11
    He thinks the hub has slowly expanded from heat, the race spins freely where the bearing sits in it.
    Do I need a new hub?
    Sep 2010
    1999,VX, 2477
    Thanked: 8
    Hmmmmmmmm....pretty sure we use the same hub as the same year Trooper 4x4s. I've never heard of what he's speaking of, TBHWY, but you have all that stuff apart, I'd go for the replacement, depending on the price (<$250).
    As a friend of mine used to say, "Do it right, cry once."
    2000, Ebony, VX, 0370
    Thanked: 12
    Say what!? I've repacked my front wheel bearings three times now and I thought that the race was part of the hub and not a separate pressed in piece. Huh, learn something new every day.
    How would the race have separated from the hub assembly? If your mechanic thinks that the hub expanded due to excessive heat then you must have had a stuck brake caliper or some dry bearings that were creating the heat. The hub is a big chunk of metal so it must have been an amazing amount of heat.
    I'm with eternal. I would think that the VX would use the same hub as a four wheel drive Trooper but I don't know for sure.
    2000 IronMan #11
    I should have taken a pic. This is new to me.
    The thin band of metal that they are putting around the outer bearing on the hub attached to the rotor. Looks like a large metal ring that supposedly sits first and the bearing inside?
    Is this wrong and he is not sure what he is doing?
    Thanked: 12
    I'm totally confused now. I have some pictures of my hub from when I re-packed my bearings, but apparently I can't access my pictures from my work computer. I'll have to get on my computer at home tonight and post up some pictures so we can have a visual reference.
    Thanked: 12
    Do any of the pictures in this thread help?
    http://www.vehicross.info/forums/sho...epack+bearings
    These are the same, basic, pictures that I have. I actually followed Kenny's write-up when I re-packed my bearings.
    EDIT: Huh, I just re-read Kenny's write up and he DOES mention removing the old raceways and installing new ones. I can't believe that I JUST caught that. I did NOT replace my raceways when I re-packed my bearings (any of the three times).....maybe I should have.
    2000 IronMan #11
    So is he just not pressing my raceways in tight enough?
    Thanked: 12
    I honestly don't know. Heck, I didn't even know that they came out until just a couple of hours ago. Looking at Kenny's pictures, though, it looks like the raceways would bottom out on a lip that is machined into the hub so if your mechanic has put them in and they are bottomed out and the still spin around then maybe your hubs are shot. Never heard of this happening to anyone before.
    Shot in the dark, but is he sure that he got the right raceways and bearings? Maybe the raceways (and bearings) are too small for the VX hubs? I just can't imagine a hub wallowing out enough to make the raceways loose. There is a lot of metal there and it would be tough to damage it because it should all be nice a snug and not have any play in it. If the hub nut wasn't tightened down properly maybe it allowed the hub to move around and get damaged, but I would think that either the bearing or the raceway would get damaged well before the hub would. Have you seen the hub? Does it look pitted or oblong like it was flopping around and getting damaged?
    2000 IronMan #11
    It looks normal! He called me and tried to explain and I was lost as you were earlier.
    Then I went there and seen it move and knew it wasnt supposed to do that....but maybe he hasnt pressed them down enough? Would they press themselves after he reassembled it?
    The bearings and old race way didnt look bad either.
    Thanked: 12
    Does he still have the old race ways? Are they the same size as the new race ways? Can he put the old race ways into the hubs without them rattling around? If the old ones fit without rattling then the new ones MUST be the wrong size.
    Per the drawing in Kenny's write up it looks like the races would bottom out in the hub and it looks like Kenny set them in with a special tool to help hammer them into the hub nice and straight. I wouldn't count on the races settling into the hubs correctly if you just start tightening things down. If you (or your mechanic) did do that I would think you might damage the bearings as they will be trying to push the races into place and bearing all the compressive forces. The races also may not completely seat in correctly.
    Since I've never replaced the races this is all just theoretical. Hopefully someone who has actually done this will chime in soon.
    Nov 2007
    1997 SILVER
    I have not done the VX wheel bearings yet, but just about every car on the road uses the same principles.
    For each wheel bearing there is an inner cup (comes with the rollers and cage assembled) and an outer cup.
    The outer cup has to be a tight press fit into the hub. If not the hub will flog out, and you cannot get the correct preload on the wheel bearings.
    It is unusual for a hub to go bad, but it can happen in extreme cases like totally stuffed bearings or a dragging brake calliper, but the old bearings would look blue from the heat before the hub would expand.
    What degree of looseness is there?? Does the outer just fall in with say 1/16" clearance all round it?? or fit snug but still turn??
    What quality bearings have you got?? Cheap Chinese ones have wider production tolerances, so you might have some right on the small end of the scale. Good boxed Timken bearings would be first choice, but there are also other named brands you can trust. (SKF, NGK, TOYO etc)
    You can get different sized outer cups to suit the same size inner cups, so I am concerned that he might have the wrong bearings. Might even be a metric vs imperial problem. Easy way to test that is try the same bearing cup in the opposite hub. You would not have 2 hubs gone, so if the bearing fits one and not the other it would give some confidence that the hub is shot.
    If the hub is worn there are a few options -
    1. New or second hand hub would be the best.
    2. Bearing companies do make thin spacers to allow a hub to be machined and the spacer press fitted, then the bearing press fitted. A machinist would have to carefully measure up the hub to determine if there is enough meat there for this process.
    3. The hub could be built up by weld material in the bearing seat area, and then the hub machined back to standard. This requires both a welder and a machinist that know what they are doing.
    Personally, I hope you just have a dodo mechanic that doesn't realise he has the wrong bearings, but this has to be made safe, so no short cuts.
    Good luck
    PK
    The OEM bearings are SFK. And I agree with what PK said above.
    2000 IronMan #11
    Thanks for all your advice/info.
    My first question to him was "you pressed them right?" Kinda pissed him off. Iv never used this guy before, big shop, all his, and it directly across the street from work. So it was a huge convenience thing.
    - I have not verified what brand and part number he ordered but I was supplied with( Timken NP654538 )and gave those to him in a box. I was going to do this repair myself so I bought everything but he didnt care for putting on parts I supplied so he did buy some bearings. Im not 100% if it was my bearings that were the problem or his. Right now he left the old ones in as is until he could source hubs. He really thought I needed some, of course, cause it is also more $$ to him.
    - I saw the play, decent snug but with play, not ridiculously easy to turn with your finger but pivoted like a teeter totter more so.
    - He did mention that locktite makes a product that could help seat it.
  1. A/C Problems : Fan motor not working, and other issues.
    By TEXAGGIE-VX-01 in forum VX Talk...
    Last Post: 10/05/2015, 12:22 AM
  2. ECORS Race VX
    By Buffy in forum VX Talk...
    Last Post: 08/27/2015, 09:12 PM
  3. VX Race Truck
    Last Post: 03/21/2012, 04:50 PM
  4. Need Help Sourcing HID Kit
    Last Post: 05/31/2011, 09:16 AM
  5. Big Race
    Last Post: 04/04/2005, 12:54 PM
