Results 1 to 4 of 4
Thread: Transfer Case leak?
    Jul 2014
    2001 Pearl White Vehicross 1455
    Wrench Transfer Case leak?
    I'm trying to run down an ATF fluid leak on Pearl. I suspect it may be the switch in the pic is leaking. I believe that is the 4H4L switch? Can someone confirm that for me?
    If so;
    1) Can I remove it without loosing a bunch of ATF fluid? Or do I have to drain the case first?
    2) How do I find a part number for this if I need to order a new one? I don't see any part number listed in the service manual.
    I didn't find it in the attached parts list either but maybe you'll have better luck than I.
    Jul 2014
    Ok, it looks like I may have found my leak and it appears to be the drive shaft seal on the front of the transfer case (front wheel drive shaft). But, "tom4bren" was kind enough to post the VX Parts List but the transfer case info isn't in that document! Is there a driveline supplement or something? I'm looking for that seal number. It shows it in the service manual but no part number there either.
    Current caretaker of The elusive 2001 "Pearl White" VX - The last one.
    1988 BMW 325ic
    2001, Dragon Green, 1342
    think you might find your part on Rock Auto dot com. Transfer case is listed under drivetrain
  1. Transfer case #'s
    By simonsayz1 in forum VX Talk...
    Last Post: 01/29/2015, 01:01 PM
  2. Transfer case leak with Pic
    By Troysaddress in forum VX Troubleshooting...
    Last Post: 08/16/2010, 04:45 PM
  3. Others cars that use our transfer case
    By VX-157 in forum VX Troubleshooting...
    Last Post: 12/08/2009, 06:08 PM
  4. 2WD transfer case?
    By So-CalVX in forum VX Talk...
    Last Post: 03/03/2008, 09:40 PM
  5. Transfer Case
    By yal^ in forum VX Troubleshooting...
    Last Post: 04/16/2005, 10:12 PM
