Page 2 of 2 FirstFirst 1 2
Results 16 to 28 of 28
Thread: Ball Joint Replacement
    2000 IronMan #11
    How do you test a bad fan clutch?
    Mine arent flipped yet and my camber has never been too bad, but I plan to flip when I tackle this repair. I have one of the lifetime firestone alignment plans.
    Sep 2010
    1999,VX, 2477
    Thanked: 8
    I've always heard to spin your fan manually. Lack of resistance = bad fan clutch, so I'm told. However, my fan spun with resistance, so I dismissed it.
    Truck had 75kish on it when I got it, and this problem started then. Given what I've heard/read/seen, I'd think if your truck is around that mileage, it is a strong possibility. When I replaced it, and the problem officially stopped, I ordered another to keep as a spare. Later on down the road, it'll be a life saver, I'm sure.
    2000 IronMan #11
    I had decent resistance. It didnt spin longer than normal after shut off either.
    Im wondering if this is leading to an overheating trans?
    Sep 2010
    1999,VX, 2477
    Thanked: 8
    Yeah, same thing I said, which is why I resisted changing it.
    What's your current mileage?
    2000 IronMan #11
    2000 IronMan #11
    So if yours passed the test(s), but then changing it solved the problems, maybe I need to bite the bullet and buy yet another part.
    2000 IronMan #11
    Ordered one from Advanced Auto.
    - Ran a couple more tests and paid better attention. It never reduces in speed or increases. Then I did a newspaper test I read about. And it easily failed that one. It said if a rolled wad of paper can stop the fan at op. temp then its defective. Looks like its been running in a low frozen state.
    Sep 2010
    1999,VX, 2477
    Thanked: 8
    Good man, let me know how it goes!
    2000 IronMan #11
    Looks to be a simple repair. Right?
    Sep 2010
    1999,VX, 2477
    Thanked: 8
    Relatively. 4 (10mm, IIRC) nuts hold the fan to the fan clutch. Then 4 more nuts (12mm or 14mm) hold the fan clutch in place. Removal of the fan is somewhat interesting b/c the space is tight due to the radiator being in place.
    Make sure you pay attention when replacing the fan to make sure that you don't put in on in reverse.
    2000 IronMan #11
    Im calling my go to cheap mechanic tomorrow for the ball joint repair!
    This fan clutch didnt go as planned:
    Had to make another trip back for the specialty wrench
    Then I stripped a nut...long story short, I filed it down till it wore off
    So now I gotta make a trip in the a.m. for nuts
    2000 IronMan #11
    Welp, couldnt get a hold of him yet. He is anti technology and never answers his home phone. The guy does good work and dirt cheap where you feel like he lost money working on it. I always tip him, its that bad.
    Anyways, worst case scenario, what would you pay a shop to complete this repair?
    Also, if all four are bad (split boots), how likely is a major wheel popping off failure? I drive 10-20miles daily starting tomorrow of 70mph interstate.
    Hey guys
    sorry to bring up an old thread.
    I need to replace all 4 Ball Joints and was wondering what the BEST ones are that I can get(upgrade over stock). I've looked at a few but I have no knowledge of Ball Joints. I was looking at Indy 4X's premium Ball joint set but at $400 its a little pricey.
    Make it yours, but make it classy........ unless theres zombies.........thats when the gun rack goes in.
  1. Ball Joint Flip - Did you do it? Why? Why Not?
    By taylorRichie in forum VX Modifications...
    Last Post: 02/05/2016, 09:07 PM
  2. ball joint replacement
    Last Post: 05/26/2015, 06:30 AM
  3. Replies: 6
    Last Post: 07/18/2014, 09:39 PM
  4. Ball joint replacement set
    By samneil2000 in forum VX Talk...
    Last Post: 03/01/2011, 09:06 AM
  5. Ball Joint?
    By V12BMW in forum VX Talk...
    Last Post: 11/13/2004, 09:42 AM
