Results 1 to 7 of 7
Thread: Tire with slow leak
    Feb 2003
    2001, Black, VX, 0781
    Tire with slow leak
    My right rear tire has developed a very slow leak. Seems to take about 2 weeks to go from full to noticeably low. It is a stock 18" tire.
    Can this kind of problem be easily fixed? If so, any suggestions on how to do it myself or how much I should expect to pay to get it fixed?
    Jun 2003
    01,black,vx,
    Unhappy
    my wife had the same problem on her car. it was a leaking valve stem small $$ to fix.
    i also need so help! i bought some mich. 275/55/18 for my stock rims and the tire shop could get it to pop the bead!? does anyone else have this problem with puting on oversized tire?
    A slow leaking tire can be repaired (patched) by any tire shop as long as the hole/leak is not in the sidewall. Around here it costs 8-10 dollars. Much cheaper than a new tire.
    I've had success with the Monkey Grip plug kit that you can buy in any Kmart and it only takes five minutes once you locate the leak. I probably plugged my old Bridgestones 4 or 5 times in the last year. They were very susceptable to nails and screws when the treads got low.
    Gregg
    2001 Proton Yellow #1379
    Feb 2003
    slow leak??
    had a slow leak on one of my Swampers. Problem was is that when I "air down" to 12-15 psi to go wheeling, the bead is vunerable to obstructions such as dirt, sticks, weeds, mud...etc
    These cause it not to seal properly and after you inflate it leaks slowly....mine started out to go flat after one month...then one week...then everyday...then overnight.
    Went down to tire shop and had them remove the tire from the rim, clean the bead area, and then put sealent all around the rim where tire sits and then remount and balance. Problem solved!!!
    You know, you can get that fixed for free at a lot of tire places! I would get it fixed before it causes a problem! You know it looses air, so I would take it in where they can find the leak!
    You could always try the " spray bottle of soapy water" technique to locate the source of the leak.
  1. Going Drag racing in the slow lane!
    By ohiovx in forum VX Talk...
    Last Post: 11/07/2015, 12:20 PM
  2. Driver's Window slow to raise
    By curiouswords in forum VX Talk...
    Last Post: 05/11/2006, 10:41 AM
  3. slow starting
    Last Post: 03/09/2006, 07:13 AM
  4. Slow/dead windows
    By Apostle in forum VX Troubleshooting...
    Last Post: 12/22/2003, 05:40 PM
  5. Vmag dying a slow death?
    By Panther_Black_VX in forum VX Talk...
    Last Post: 05/28/2003, 10:31 AM
